Reply
Old 18th Apr 2024, 7:37 pm   #1
IanNVJ35
IanNVJ35's Avatar
Default Panasonic FJ760 white dots on image
I have on the bench one of these VCR's from around 2000 - Z mechanism.
It has a fault that also plagued the FJ710 and 765 models, namely white dots on playback over tge image.
Now I remember years ago some bulletin about this, something to do with grounding two parts together, but I cannot find it now.
If anyone remembers it would be much appreciated as it's an otherwise excellent machine in good order. Just the 'sparks' going across in twos at an angle do spoil it.
Cheers.
IanNVJ35 is offline   Reply With Quote
Old 18th Apr 2024, 8:48 pm   #2
Red to black
Red to black's Avatar
Default Re: Panasonic FJ760 white dots on image
Panasonic NVFJ610
We've had several of these and similar models with the
complaint of static 'blips' on the playback picture. In some
cases the cure has been to clean the PCB land that earths the
metal bottom panel. Some however can be dealt with properly
only by replacing the earthing brush that's buried under the
upper drum. Panasonic has available a rather expensive
conductive oil with which to anoint the shaft. E.T.
C/O TV Magazine
Red to black is offline   Reply With Quote
Old 18th Apr 2024, 8:50 pm   #3
IanNVJ35
IanNVJ35's Avatar
Brilliant. That was it. Now to have a go!
Old 18th Apr 2024, 10:28 pm   #4
IanNVJ35
IanNVJ35's Avatar
You can see the dirt and failed connection. Cleaned and re-flowed.
Old 20th Apr 2024, 9:26 am   #5
IanNVJ35
IanNVJ35's Avatar
Just to add one more point. I sourced some conductive oil at a local hobby shop (its rail lubricant Peco PL-64 - £10 for around 7ml) and cleaned and lubricated the head shaft. The anti static brush was perfect condition. The image quality is now perfect without a single dot. So this is worth doing if you have the dots.
Old 20th Apr 2024, 11:03 am   #6
Red to black
Glad you got it sorted
Reply
