Old 8th Jul 2021, 3:14 pm   #1
bobhowe
bobhowe's Avatar
Default Mullard UF 41 Date Code How To Identify Year?
Hi i am trying to identify the year where this Mullard UF 41 was made there are no etched codings on the side but painted next to the valve pins in white are Nm7 BA5 is this the date code and how do read the code ? kind regards Bob
bobhowe is offline
Old 8th Jul 2021, 7:41 pm   #2
AC/HL
AC/HL's Avatar
Default Re: Mullard UF 41 Date Code How To Identify Year
https://mullard.org/blogs/news/mulla...interpret-them
BA5 looks like Blackburn, January 1955.
AC/HL is offline
Old 8th Jul 2021, 7:47 pm   #3
snowman_al
snowman_al's Avatar
Everything you need to know here:
https://frank.pocnet.net/other/Phili...CodeListAB.pdf
Never Leave Well Enough Alone...
snowman_al is offline
Old 9th Jul 2021, 11:16 am   #4
Maarten
Strange code. Doesn't confirm to the 1948-1956 standard as the second line has 3 positions, nor to the later standard as the A and the 5 seem swapped.
Possibly Mullard got rid of the old coding system before Eindhoven had set a firm standard for the new one. In that case I would tend to agree on january 1955.
What construction does it use? Is the tube fritted (looks like transparent glue but is actually a layer of low melting glass) to the bottom and does the bottom plate have green 'beads' around the pins (which are stiff, not bendy)?
Given the factory stamping is on the bottom and not on the side, I suppose the bottom is fritted?
Maarten is offline
Old 9th Jul 2021, 7:23 pm   #5
bobhowe
bobhowe's Avatar
Hi thanks for replies to everyone i would say it is January 1955 and it does have green beads around the pins and it has no factory stamping on the side and it is on the bottom kind regards Bob
bobhowe is offline
