Reply
Old 3rd May 2021, 9:50 am   #1
mickydel
Default Kawasaki ks-20 cable repair
I am a new joiner and have an older JVC radio where the cable has frayed over the last 30 years. Does anyone have an idea if this can be repaired or a replacement bought for the radio cable? The radio still works fine, but I need to decide on re-chargeable batteries or the preferred option which is to fix the cable and to try to keep it original.
Many thanks.
Michael.
mickydel is offline   Reply With Quote
Old 3rd May 2021, 10:00 am   #2
Station X
Station X's Avatar
Default Re: Kawasaki ks-20 cable repair
I'm not sure whether you're referring to a Kawasaki or a JVC radio.
Is it the mains lead that's fraying? Can you post a picture of it please, clearly showing the connectors.
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is offline   Reply With Quote
Old 4th May 2021, 9:11 am   #3
davidw
davidw's Avatar
I think its the mains lead that is made by Kawasaki and used on a JVC radio. A quick search shows various 2 wire types.
Dave G1AGK.
My perception is my reality!
davidw is offline   Reply With Quote
Old 14th Jun 2021, 12:50 pm   #4
mickydel
Hi davidw and Station X, Many thanks for your replies and my apologies for not replying sooner. The cable is a Kawasaki Ks-20 and it is for a JVC 'boombox' from the 1980's. I have attached 2 pictures.
Best regards.
Michael.
ID:	235886   Click image for larger version
Old 14th Jun 2021, 2:03 pm   #5
Station X
Station X's Avatar
We need to see the end of the connector so we can see what shape the sockets are.
It's of moulded construction, so a repair is not possible unless a screw together type connector can be found.
Old 14th Jun 2021, 2:33 pm   #6
mickydel
Hi Station X, I have attached a further 3 photos. Hope this helps?
Michael.
Old 14th Jun 2021, 6:16 pm   #7
FIXITNOW
FIXITNOW's Avatar
Michael.
sadly the pictures are missing
FIXITNOW is offline   Reply With Quote
Old 15th Jun 2021, 7:26 am   #8
mickydel
Hi Station X, My apologies, I must have forgotten to press the 'upload button'...Have had another go and it looks better now.
Best regards.
Michael.
ID:	235918   Click image for larger version
ID:	235919   Click image for larger version
Old 15th Jun 2021, 9:53 am   #9
crackle
crackle's Avatar
You may find the very common standard figure of 8 mains lead will fit. https://www.amazon.co.uk/DabbersIT-P...3750652&sr=8-4
You probably have one somewhere in the house to try, and I would try one before you buy as there may be a switch associated with when the mains plug is pushed in to disconnect the batteries.
Mike
BVWS Member, 2E1MJE
The KB Museum
My collection in the Radio Museum
crackle is offline   Reply With Quote
Old 15th Jun 2021, 9:55 am   #10
HamishBoxer
HamishBoxer's Avatar
I was going to say that too, it certainly looks a though a figure 8 might well fit. I am sure though I have seen the one shown before somewhere.
HamishBoxer is offline   Reply With Quote
Old 15th Jun 2021, 10:26 am   #11
Nickthedentist
Nickthedentist's Avatar
If you can't easily get a cable to fit, it might be easier and safer to run the radio from the mains via a plug-in power supply, a bit like a the things that you get with a broadband router, cordless landline phone and countless other things around the house.
The voltage, maximum current and polarity (i.e. which way round + and - go) are vital though, so don't experiment until you've checked with us.
If there isn't a DC input socket, you'd have to open up the radio and solder the wires from the power unit to the tags on the battery holder contacts. Not difficult if you have some experience, but not recommended for an absolute beginner.
What's the model of the radio, please?
Nickthedentist is offline   Reply With Quote
Old 15th Jun 2021, 11:38 am   #12
mickydel
Thank you all so much for your time and help. I am going to have a search around the house to see if I have a figure of 8 cable. If I can't find, I might try a shop and see if I can find one that fits. The model of the radio is RC-656W and is a JVC Dolby System Radio / Cassette Recorder. It used to be referred to as a 'boombox'. My older brother bought it for me as a present when he was working in Saudi Arabia when I was a teenager so it has sentimental value (I am now 62). I have attached a picture. I will update when I have found a cable and thank you all again for your help.
Best regards.
Michael.
Old 17th Jun 2021, 4:21 pm   #13
usradcoll1
I have a 29 year old portable Panasonic CD, radio, that has a mains lead similar to yours, but with a US plug. The female connector is the same and made by the same company, Kawasaki.
Unfortunately the figure 8 connector doesn't fit! I can't see the difference with the naked eye, whether it's the pin spacing or diameter of the pins.
The proper one might turn up eventually.
Dave, USradcoll1
usradcoll1 is offline   Reply With Quote
Old 17th Jun 2021, 5:23 pm   #14
merlinmaxwell
merlinmaxwell's Avatar
A touch of super glue (fantastic for PVC used in the cable) and a bit of heatshrink tube it will be as good as a bought one.
Cats have staff, it's dogs that have owners.
merlinmaxwell is offline   Reply With Quote
Old 17th Jun 2021, 7:57 pm   #15
Nickthedentist
This JVC apparently has a 12V DC input, so running it from an external power unit rated at a couple of amps should be easy.
Old 17th Jun 2021, 8:13 pm   #16
Bazz4CQJ
Bazz4CQJ's Avatar
I think these plugs are still being made but are quite unusual. I bought a grit-blasting cabinet last year and I think that has one for the 12V interior light.
Many years ago, some Japanese companies fitted them as mains connectors on some radios, but they are definitely sold as low voltage connectors now.
Some time ago, I ran a thread asking if anyone had such a lead for a Sanyo radio I have and one member very kindly came up with one. If I can find the thread, there may be some info there. Figure of 8 connects won't work.
B
Data beats opinions most times... that's my opinion, though I have no data on that.
Bazz4CQJ is offline   Reply With Quote
Old 18th Jun 2021, 6:29 am   #17
crackle
crackle's Avatar
BVWS Member, 2E1MJE
The KB Museum
Old 18th Jun 2021, 7:01 am   #18
mickydel
Finally managed to locate a 'figure of 8' plug but it did not fit. I am not sure if there are any variations for the 'figure of 8' that I should try...is there a smaller 'figure of 8'? I have attached a photo of the socket and the new plug...There is a slight difference in size.
Best regards.
Michael.
Old 18th Jun 2021, 8:12 am   #19
eddie_ce
eddie_ce's Avatar
I seem to remember that the plug for the Braun electric razor was smaller than the normal figure of eight. Possibly an option?
Eddie
BVWS Member.
Friend of the BVWTM
eddie_ce is offline   Reply With Quote
Old 18th Jun 2021, 10:03 am   #20
boxdoctor
boxdoctor's Avatar
In the '70s, when I was working for Comet, we had quite a few different radios/cassette players etc. to service with this type of mains plug. They were of oriental origin, but I don't recall any being specifically Japanese.
The dimensions are just that bit different to the common "Figure of eight" type , and they almost all were used with a mechanism which did automatic battery/mains switching, which relied on the shape of the plug body to work properly.
I would think they can still be sourced somewhere on the net. Tony.
The job "couldn't be done".
He didn't know that,
So he did it.
boxdoctor is offline   Reply With Quote
Reply
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
