Old 1st Aug 2019, 5:08 pm   #1
amillar
Default Noisy Decca TP85 - ideas?
I've been restoring my wife's TP85 from her childhood, which was in a pretty awful state. All sorts of things living inside it. With the aid of a donor set for speaker, aerial, buttons and battery connectors, and after fixing a crack in the PCB, it remarkably came back to life. But very noisy (RF noisy). I'm only trying to get the FM working.
Got hold of a TF2015 FM generator and aligned it last night - my first time ever aligning an FM set in 50 years of mucking around with analogue electronics! - and it made no improvement at all. In fact the alignment seemed pretty spot on - I just took it out of alignment and back again.
So now I need to take the PCB right out, remove the blessed screening can again, and have a proper look now I have the sig gen. But before I do I thought I'd ask here if anyone had any good guesses of where to look which could save unnecessary pain and grief - from other posts here it looks like others will have been there, done that, and got the tee shirt.
Here's some clues: The adjustments on the first RF stage, L1 and C9, did absolutely nothing (L3 and C15 on the second stage worked perfectly). So does this suggest that the first stage AF114 is suspect? Or something else? I know the dc voltages around the RF transistors all seemed ok when I first stripped it down and rebuilt it - the cracked track was in the common rail of that first RF stage so I had a good check around when I was finding and fixing it.
And also RV1, the balancing adjuster in the demodulator, did absolutely nothing on the AM rejection test, even swinging it from end to end.
I've got the "Trader" sheet for it which got me this far.
Any thoughts welcomed and appreciated!
I'm very pleased with the TF2015 (fortunately I already had a decent Philips frequency counter) - after all these years I still get FAR too much fun out of playing with a "new" piece of test kit
Cheers,
Andy
amillar is offline
Old 1st Aug 2019, 6:07 pm   #2
Nuvistor
Nuvistor's Avatar
Default Re: Noisy Decca TP85 - ideas?
Any AF11x transistor can be suspect, a bit more testing though before removing it. They grow tin whiskers inside the can and s/c the connections.
https://www.vintage-radio.info/whiskers
Frank
Nuvistor is online now
Old 1st Aug 2019, 6:13 pm   #3
Andrew2
Andrew2's Avatar
Hi Andy. An AF114 of that vintage has got to be suspect, either through the dreaded 'tin whisker' blight or just general degradation. Tin Whisker would greatly upset the DC voltages though.
As the original PCB crack was in the RF area it's worth having another look - there may be a second crack nearby.
As for the non-operative balancing pot in the FM demod, it could be the pot itself or that old favourite electrolytic across the diodes gone dud.
Andy G1HBE.
Andrew2 is offline
Old 1st Aug 2019, 9:31 pm   #4
amillar
Many thanks, as soon as I've cleared a bit of space on my workbench I'll have a go at it!
Cheers,
Andy
amillar is offline
