Old 24th Jul 2019, 9:06 pm   #1
tim.norris
Default Hacker VP 408
Have just bought a Hacker RP38 Radio which came with a working VP408 power adaptor . the adaptor was rather grubby to say the least but after a strip and clean it's come up rather well. Unfortunately someone has driven 2 self tappers in to hold it together, does anyone know the length and thread of the original screws?
Regards, Tim.
ID:	187281   Click image for larger version
ID:	187282   Click image for larger version
tim.norris is offline
Old 24th Jul 2019, 9:14 pm   #2
BRASSBITS
Default Re: Hacker VP 408
What makes you think the self tappers are not original?
BRASSBITS is offline
Old 24th Jul 2019, 9:19 pm   #3
Nuvistor
Nuvistor's Avatar
I have one, cannot remember the screw types, I will not be able to find out for a few weeks, if you still the information then I will have a look at mine which is original.
Frank
Nuvistor is online now
Old 24th Jul 2019, 9:23 pm   #4
tim.norris
Hi, looking at pictures on the internet the original screw heads look to be recessed in the bottom cover also the locating plastic lugs look like they are threaded to accept screws , i could be wrong but the self tappers don't look very refined for a Hacker!
Regards, Tim.
Old 24th Jul 2019, 9:26 pm   #5
tim.norris
Thanks Frank it would be much appreciated, everything else seems to be original as it came with the original plugs and lead to fit the radio.
Regards, Tim.
Old 24th Jul 2019, 9:42 pm   #6
BRASSBITS
Have you got any screws to try in the threaded part to discover the thread type/diameter?
Old 24th Jul 2019, 9:50 pm   #7
Nuvistor
Nuvistor's Avatar
Found this photo on the internet, it shows recessed screw heads.
Frank
Old 24th Jul 2019, 10:10 pm   #8
ajgriff
ajgriff's Avatar
Trouble is that the original screws may have been replaced with self tappers because the lug threads got stripped by overtightening in which case the correct screws won't tighten properly anyway.
Alan
ajgriff is online now
Old 24th Jul 2019, 10:14 pm   #9
BRASSBITS
Alan
There's also the possibility the self tappers have totally destroyed the original thread.
Old 25th Jul 2019, 10:35 am   #10
Herald1360
Herald1360's Avatar
If there's enough "meat" on the pillars, tap them up to the smallest oversize thread that works then fit some suitably "quality" looking screws. A coarse thread might be better than a fine one for this. A note inside the box about it might just help someone else later on.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 26th Jul 2019, 12:04 am   #11
mhennessy
They are 52.7mm long (including the screw head) and at first glance look like M3.
Of course, they aren't M3; they are 6BA, and 2" long in old money.
Hopefully the self-tappers were not long enough to reach the brass inserts.
mhennessy is offline
Old 26th Jul 2019, 8:26 am   #12
tim.norris
Mhennessy , many thanks will try and source a coouple , the threads look good as the self tappers are much shorter , regards, Tim.
Old 26th Jul 2019, 9:13 am   #13
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
I should have some 6BA screws somewhere-not sure if I have any 2" long, but if you can't get any, PM me, and I'll send you a couple. Mine have slotted heads rather than Phillips or Pozidrive, not sure what heads the originals had.
'LIVEWIRE?' is offline
Old 26th Jul 2019, 10:17 am   #14
mhennessy
They're slotted.
Unfortunately, they do need to be that length because of the location of the brass insert. While that's a pain, that did at least protect the insert from the errant self-tappers
If anyone finds a source, let me know as I need a couple for my other VP408.
Old 26th Jul 2019, 10:54 am   #15
ajgriff
ajgriff's Avatar
Plenty on eBay in brass or plated steel.
Alan
Old 26th Jul 2019, 11:09 am   #16
'LIVEWIRE?'
I have sometimes found that sellers at events such as Steam Rallies & Classic Car Shows stock BA thread screws, nuts & bolts, along with many othr items.
Old 26th Jul 2019, 11:26 am   #17
BRASSBITS
looking at the photo on the internet post 7
they appear to be cheese heads
Old 26th Jul 2019, 11:43 am   #18
Mike. Watterson
What thread are screws for mains sockets and switches? Our local HW store sells brass and chrome effect / colour versions in long lengths in packets, no doubt for boxes fitted too deep in the wall. Very cheap. They aren't metric. But then gas and water is still imperial here. You need an adaptor for any gas cooker sold by the usual UK chain stores here. Not included. Argos sold UK phones here for years without adaptors. Some adaptors have no capacitor, which meant phones or fax for the UK market didn't ring.
Mike. Watterson is offline
Old 26th Jul 2019, 12:49 pm   #19
mhennessy
Yes, they are cheese head.
Searching eBay, plenty of 6BA: yes. 6BA 2" cheese head: no. Out of the 3-400 results, just 3 listings on the whole site. One for brass, and they appear to be new, but the steel ones are NOS. Of those 2, this appears to be the most promising: https://www.ebay.co.uk/itm/6ba-X-2-C...0/323851574172
Electrical fittings use M3.5 over here.
Old 26th Jul 2019, 1:22 pm   #20
Mike. Watterson
Probably any fittings bought in UK owned stores here are 3.5mm then.
Which is most stores.
