Old 30th Sep 2023, 10:54 am   #1
pudwink
Default 1975 Sinclair Black Watch Help If Possible
Hi All
I have been after one of these watches for years and recently purchased one but as normal with these it is faulty when batteries are put in it you get a led lighting up so it has some life.
I have removed the module and the back circuit has some issues
As you can see in the pic there is a break and a track lifted on the red side and track lifted on the blue side but can't work out if they should be connected to anything.
If anyone can help I would be very grateful.
Many Thanks
Name:	Sinclair Watch Circuit.jpg
pudwink is offline
Old 30th Sep 2023, 11:03 am   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: 1975 Sinclair Black Watch Help If Possible
I think I know where my Black Watch is if so I'll drag it out of hiding later hopefully in the mean time someone will have one to hand.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 30th Sep 2023, 9:45 pm   #3
Robsradio
Most of these were killed by static discharge, all the nylon clothes back in the day and a plastic case didn’t help, hope it isn’t dead as they were a horological milestone in the 70s
Robsradio is offline
Old 30th Sep 2023, 10:02 pm   #4
Cobaltblue
Cobaltblue's Avatar
Mine wasn't dead at the time of non use just that LCD's had arrived.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 1st Oct 2023, 4:13 pm   #5
Cobaltblue
Cobaltblue's Avatar
Well I found it and weedled it out of its case (fortunately I still have the assembly instructions)
These pics help?
Looks as if the Flexi PCB is substantially different
Mike T
ID:	285844   Click image for larger version
ID:	285845   Click image for larger version
ID:	285846   Click image for larger version
Mike T BVWS member.
www.cossor.co.uk
Old 2nd Oct 2023, 12:55 am   #6
pudwink
Hi Mike T
Thank you for taking the time to upload your pictures this is the problem I am having the only pics I can find of the flexi pcb are different to my version.
You say you have the assembly instructions is there anything on there that may be of use to me.
Many Thanks
pudwink is offline
Old 2nd Oct 2023, 8:07 pm   #7
Cobaltblue
Cobaltblue's Avatar
Sadly not much there is some detail of the tracking but I don't know how accurate it is
I'll attach the pictures sadly the instructions were damaged some time ago due to a water leak.
Mike T
ID:	285882   Click image for larger version
Mike T BVWS member.
www.cossor.co.uk
Old 2nd Oct 2023, 8:42 pm   #8
Sideband
Sideband's Avatar
I seem to recall there were a couple of versions of these watches. A friend of mine built one but never got it working. (I think it was static damage). He sent it back to Sinclair and they simply replaced it....with one that looked identical but had a date function.
I seem to recall that it ate batteries...at least the one I built did. I did get it very accurate though....better than a second a week (which is rubbish by todays standards.....)
Sideband is offline
