Sets and Parts Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
25th Nov 2023, 8:32 pm | #1 |
Bose Wave CD module.
Evening
A real long shot, I rescued an early Bose Wave with CD player, it has it’s issues, no AM reception, (not too bothered), FM works, sound is excellent. The CD player refused to work, so a quick google and it’s suggested that the laser diode output reduces over time, there is a pot to adjust, so I tweaked it up slightly, and it played 2 CDs, now it won’t even spin up or recognise a disk is present. I will admit I know nothing about CD players, so may have cooked the laser? Using a phone camera the red of the IR laser is visible, (all precautions observed). Lens has been cleaned with IPA, still dead. So does anyone here have a 2020 year model being broken for parts? Regards Rob |
26th Nov 2023, 6:29 pm | #2 |
Re: Bose Wave CD module.
Does sound like a worn out/faulty laser assy. It is possible that the actual laser assy is not made by Bose, for instance it might be a Sony KSS type. Might be worth adding a picture of the laser assy in it's deck for possible identification.
Dave
26th Nov 2023, 9:26 pm | #3 |
Thanks Dave, good thought, will post a pic when I’m next in the workroom.
27th Nov 2023, 6:01 pm | #4 |
These machines suffer from bad SMD caps on the board above the deck. This causes skipping and mechanical noise which may (or may not!) be your problem.
The laser assemblies you can buy (they aren't KSS unfortunately) are pretty hopeless in my experience. |
27th Nov 2023, 8:27 pm | #5 |
The various Bose Wave models are notoriously difficult to repair.
27th Nov 2023, 11:47 pm | #6 |
I dunno, I found the 2 I’ve played with rather easy to fix! As Glyn says, dodgy SMD caps in the newer one got it playing again, they can cause the ‘please wait’ on power up to stay on the display for too long, as well as causing the CD player to report no disc or skip. That one’s still working well as my alarm clock! The other one was an older model, I think someone may have puked on it (yuck!!) and it had eaten some tracks around an OP amp chip, so the +15V on the IC was missing, and the whole machine had turned into a very loud car horn, a damn good clean and repair of damaged tracks, replacement of a few knackered SMD resistors and it’s back working properly, without the loud horn noise!
Regards Lloyd |
28th Nov 2023, 1:59 am | #7 | |
How were you able to identify the duff capacitors? I usually run a mile when confronted with SMD, so beyond dismantling it to clean the laser and finding nothing obviously wrong I haven't touched it since. |
28th Nov 2023, 10:06 am | #8 |
Hi Rob,
Please post a few photos of the CD mech. I have a good one from a scrap system, but a different year, so need to compare. Cheers. |
28th Nov 2023, 11:08 am | #9 | |
28th Nov 2023, 11:23 am | #10 | |
I can certainly agree that the price is intimidating! Even broken ones seem to fetch a good price!
Regards Lloyd |
28th Nov 2023, 11:39 am | #11 |
Thanks for all the info gents, thanks Adrian i will try and get a photo of the mech and upload it.
The reason I think I may have killed the laser diode is by increasing the drive voltage as per a you tube clip, it played a couple of CDs then died and won't even acknowledge that a CD is in it now. |
28th Nov 2023, 11:58 am | #12 |
The laser certainly does fail in these units.
28th Nov 2023, 12:03 pm | #13 |
As I mentioned, replacement lasers are expensive and, crucially, not very good quality.Is it stillemitting laser light? If so you might be in with a chance.
Lloyd is right - change the capaitors for 'proper' ones. They need to be very good quality - it's very fussy. |
2nd Dec 2023, 2:43 pm | #14 |
Finally had a chance for some photos...
4th Dec 2023, 10:52 am | #15 |
OK, I have compared your photos against the unit I have and regret that the lasers are very different, so unfortunately cannot help in this instance.
5th Dec 2023, 9:53 am | #16 |
Thanks anyway Adrian, I will probably just use it as a shed radio.
5th Dec 2023, 9:57 am | #17 |
I would do just that. And maybe add Bluetooth too.
I wonder who made the optical block? Is that a Matsushita or Mitsubishi logo I can see on the foil side of the PCB? |
5th Dec 2023, 11:09 am | #18 |
That looks like the earlier model, were they still making those in 2020? The mode I was thinking of was the one with the slot loading CD player. Not sure if this model suffers the same problem with the knackered SMD caps.
5th Dec 2023, 12:45 pm | #19 |
I agree with Lloyd -that is an early model. It could be an Optoma drive.
I think I'd be inclined to agree and use it as a radio. |
5th Dec 2023, 1:19 pm | #20 |
Cheers gents, yes it will be a good radio, and with RCA sockets may be good for testing separates etc, may even look at having a bluetooth facility as suggested by Nick.
