Old 8th Aug 2015, 12:50 am   #21
dmaillard
dmaillard's Avatar
Default Re: Replacing Motor Run (?Motor Start?) Capacitor in AKAI 1700
Are you sure you have the lever installed the correct way? If installed correctly it cannot come out.
dmaillard is offline
Old 8th Aug 2015, 8:36 am   #22
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
As sure as I can be. I fitted it with the 'u' shaped hook end in the lever/knob assembly, as shown in that diagram, and the Right angled end through the hole marked 'C' on the switch.
'LIVEWIRE?' is offline
Old 11th Aug 2015, 9:47 pm   #23
'LIVEWIRE?'
I've since refitted the lever as per the service manual instructions, and carefully bent the hook to narrow the gap, so it shouldn't come out of the actuator on the rec/PB knob assembly again
