Old 16th Sep 2020, 5:39 pm   #101
Uncle Bulgaria
Uncle Bulgaria's Avatar
Default Re: Uher CR 240 AV Cassette Recorder
Don't you just love intermittent faults! I wonder if an expert has a thought on where that signal could be coming from. Could it be coupled earths from the PSU and the oscilloscope?
It does sound like the ICs are fried, but if you've got some more on the way then at least you'll be able to confirm or rule out that.
The right VU meter seems to have a mind of its own. When I switch on, mine leaps to full deflection and gently comes back, though it does settle to zero deflection after a second or two. It also tends to leap on the application of certain controls. Perhaps something else to investigate. It's funny it's the right one, as I would have thought the left with its dual role as battery meter would have the greater likelihood of being affected by other controls.
Uncle Bulgaria is offline
Old 16th Sep 2020, 9:45 pm   #102
DMcMahon
DMcMahon's Avatar
Intermittent faults are a pain, often they will come back with a vengeance.
Yes both my VU meters at times jump around when controls moved. My 4000 VU meter is particularly bad sometimes jumping around for no reason, others have commented that normal on the 4000, seems bad to me.
DMcMahon is offline
Old 17th Sep 2020, 9:52 am   #103
DMcMahon
DMcMahon's Avatar
Found a 7 pin DIN plug and checked the line output signals on Playback at the Radio DIN connector all OK.
Had another close look under magnifying glass at the soldering around the IC 2/3 area. Found a leg of a component had been cut off quite long and was bent over its soldered hole and resting on top of adjacent soldered track. Even though it appeared to be touching, resistance measurement did not indicate a short. While bending the leg away from the adjacent track could see (under magnifying glass) that it was somewhat loose in its soldered hole. Also another component leg on the adjacent track was somewhat loose. Resoldered these but made no difference to the fault symptoms.
Again did a batch of resistance and voltage measurements around IC 2/3 but nothing obviously indicated any possible capacitor shorts.
Decided to leave the 3 tiny Tantalums (near IC2/3) alone.
C24 (10uF) I have not yet spotted on the schematic, but does not appear to be anything directly to do with IC2/3.
C37 (1uF) is on the +9.5V supply rail, the +9.5V measures fine at the ICs. BTW C37 is incorrectly identified on the component layout drawing as 0.1uF
C26 (10uF) is part of the IC2/3 input circuitry together with 3 transistors. Not very sure of the function of this circuitry, but its function is either enabled or modified by the internal speaker switch. Because have good inputs signals at pins 7 of the ICs with zero outputs, consider at this stage that the input circuitry is not at fault.
For good measure will probably replace the 3 electrolytics per IC, C27 (100uF), C31 (100uF) & C35 (1,000uF) for the left channel.
There are 2 other small/tiny capacitors per IC on the compensation pins, C29 (0.1uF) & C32 (220pF) for the left channel, will leave these alone but will try and measure them when IC removed.
Not looking forward to replacing the ICs, will just do the left channel (IC2) to start with to see the results. Think my soldering work on delicate artwork has diminished with age and think it will be difficult to extract the ICs without track damage. Probably will cut off the IC pins at the IC body and extract 1 pin at a time, this should make it a little easier and hopefully reduce any track damage.
Do not find it easy to actually accurately see the IC artwork connections, because the adjacent pins of the IC are physically staggered on the board and some pins are not soldered (the not connected pins) not easy to see compared to a normal row of DIL IC soldered pins.
DMcMahon is offline
Old 17th Sep 2020, 10:07 am   #104
Uncle Bulgaria
You have the original circuit diagrams, don't you? I mention it because the PDF I was using before I got the originals (having told SDS my serial number) had some different values, which could be what you're seeing if it's a slightly different revision. I didn't originally have a circuit for the Hall sensor, for example, as the PDF was for the variant with the reflective strobe tape-end detection. That C37 is a 1µF on my circuit diagram, but 0.1µF on the layout drawing like yours.
The ICs are a pain (I did replace one, but it wasn't broken in the end). I recommend close attention to the big motherboard drawing with the lands and component layout shown, and get used to how many pins there are between the power board connections at the edge of the motherboard and the ICs. I spent a lot of time repairing tracks in that area so learnt my way around quite quickly. The unsoldered pins are a giveaway too. Some flux and solder wick and they come out without too much trouble.
Old 17th Sep 2020, 10:09 am   #105
DMcMahon
DMcMahon's Avatar
Have now spotted C24. around transistor T6, something to do with the control of the IC1 Op Amp for the line outputs to the DIN connectors.
DMcMahon is offline
Old 17th Sep 2020, 10:22 am   #106
DMcMahon
DMcMahon's Avatar
Yes have the original circuit diagrams which are great compared to fuzzy PDFs but still hard work at times due to eyesight not being as good as it used to be.
C37 is actually a 1uF so it is just the layout drawing showing it as 0.1uF that is incorrect.
Have never been a big fan of solder wick (I can hear people shouting why not ).
Last edited by AC/HL; 17th Sep 2020 at 2:50 pm. Reason: OT aside edited. Please start a new thread.
DMcMahon is offline
Old 17th Sep 2020, 12:16 pm   #107
Not sure if this will help but so far as I can make out T4 and T5 mute the inputs to the line output amplifiers, the mute control voltage comes in at the junction of R49 and R50.
When in Record it's via D1 and switch contacts 47-48.
When in Pause it's via D2 and R83.
When in Rew/FF it's via T6.
Same for the input to the audio output amplifiers (by T8 and T9) except that the mute function is overridden in Record by the action of T7.
Old 17th Sep 2020, 5:32 pm   #108
DMcMahon
DMcMahon's Avatar
Thank you Lawrence for the useful inputs and expert analysis as usual.
Because there appears to be useful voltage signals on the inputs to the audio output amps I do not think they are being muted in Play mode but certainly will look more closely at the muting operation to doubly check, later when I return home.
As I said previously it does seem strange if both output amps are actually dead, would be good to find something else common to them that would affect their operation.
DMcMahon is offline
Old 17th Sep 2020, 5:44 pm   #109
Uncle Bulgaria
It's probably a good idea to revisit your aversion to solder wick - if you can remove them without cutting the pins then if they later turn out not to be the problem you won't have ruined them!
I was also not convinced by it until a fortnight ago when I started dipping it in a tin of flux. Suddenly, it became brilliant and I'm now a complete convert. There are sometimes those places a sucker doesn't reach...
Old 17th Sep 2020, 6:08 pm   #110
Have you measured Vcc on pin 14 of the IC's WRT their ground pins 8 & 10?
Old 17th Sep 2020, 6:14 pm   #111
DMcMahon
DMcMahon's Avatar
Yes 9.5V
DMcMahon is offline
Old 17th Sep 2020, 11:18 pm   #112
DMcMahon
DMcMahon's Avatar
Tried a few times over many years with minimal success compared to using a solder sucker (probably just bad technique on my part), maybe I should revisit it. In this case I am not worried about ruining the old chips.
DMcMahon is offline
Old 20th Sep 2020, 8:50 am   #113
DMcMahon
DMcMahon's Avatar
Cannot find my old solder wick supplies so have just ordered some more.
Probably could have tried some copper braid off a cable with flux but as I have not had a lot of success previously, thought best to get some modern fluxed solder wick to get better chance of success.
Undecided yet whether to wait for the solder wick to arrive before replacing the IC's.
Either way will only replace one of them initially, if this does not fix the problem on that channel, then little point at that stage replacing the other one, as then it would indicate the fault is elsewhere.
DMcMahon is offline
Old 18th Nov 2020, 1:06 am   #114
DMcMahon
DMcMahon's Avatar
Reference Post 84 I had not yet got round to attempting to break the glued joint of the Record switch contact arm, but tonight while doing monitoring tests I accidentally pushed the record switch sideways while reaching over to select rewind which broke the glued joint. So now do not need to work out how to break the joint
Next need to re-glue the contact arm, rotating one of the 2 pieces 180 degrees and hopefully then get normal operation of the record switch.
DMcMahon is offline
Old 30th Dec 2020, 1:36 pm   #115
DMcMahon
DMcMahon's Avatar
I did not realise until today that CR stands for Compact Report.
DMcMahon is offline
Old 30th Dec 2020, 5:41 pm   #116
DMcMahon
DMcMahon's Avatar
I previously assumed that CR stood for Cassette Recorder.
DMcMahon is offline
Old 30th Dec 2020, 8:10 pm   #117
Uncle Bulgaria
Bizarrely, I also discovered this in the last week. A friend who lives off-grid ordered a CR 210 because of its capacity for different power supplies, and it struck me as peculiar that a German firm would use the English instead of Kassetten Rekorder or a suitably Germanic equivalent. I suppose Compact Report is English too, but less generic for Uher than 'Cassette Recorder'.
Old 30th Dec 2020, 10:21 pm   #118
DMcMahon
DMcMahon's Avatar
Yes does seem somewhat strange.
DMcMahon is offline
Old 2nd Jan 2021, 12:45 am   #119
Pine Marten
Just to let you all know, my CR240 AV is now working 100% as new, in no small part to the input of you chaps on this fine forum. I am quite surprized by the excellent sound quality which is not far from source input. By far the best I have ever experienced from cassette.
Pine Marten is offline
Old 2nd Jan 2021, 10:10 am   #120
DMcMahon
DMcMahon's Avatar
Excellent news.
DMcMahon is offline
