12th Jul 2011, 5:56 pm | #1 |
technics 103 switcher HELP needed
Hi.
I have just aquired this item without any instructions, searched the net but unable to find any details, I need some giudance on setting up , see pics Thanks. Wal |
12th Jul 2011, 6:03 pm | #2 |
The 'switcher' as you describe is a shop use 'comparator' to demo various bits of kit (amps and speakers,turntables etc)
They were never retailed to my knowledge as they have no real use in a home, and for that reason you won't find any info out there. As for setup I'd have thought it was straightforward , they are clearly marked up. You'll probably find all the push switches are knackered too, tarnished/worn contacts I junked a couple of these last year when I moved premises |
12th Jul 2011, 8:02 pm | #3 |
Re: technics 103 switcher HELP needed
Hi mikey.
The unit is in pristine condition, I want to set it up in my workshop but being a Wally I just need a little help with it. Wal |
12th Jul 2011, 8:11 pm | #4 |
It really is quite simple
Step 1 Connect all your speakers to the 'Speaker Out' connections (the read and black push connectors) Step 2 Connect all your amplifiers speaker outputs to the other red and black push connectors labeled 'Amplifier Output' - You can have five amps connected to the system. Step 3 Connect all the sources you have to the AUX input phono sockets. - you can have five sources. Step 4 Connect the aux outputs (phono pair by pair) to all your amps AUX (doesn't have to be AUX though) inputs Step 5 connect up to 5 turntables to the turntable inputs Step 6 Connect the turntable outputs to each amps turntable input preadjust the volume on all the amps beforehand and make sure only one switch on the front of the technics is selected at any one time in each group (always) and switch every thing on. Use the buttons to select which source to play out on whatever amp and whatever speaker you choose with the buttons Obviously when you're solely listening to turntables, you need to preselect turntable on all your amps beforehand, same goes if you're solely listening to non turntable sources. PS Don't do any switching at high volumes , comparators are somewhat renowned for killing amps occasionally Last edited by MikeyPP; 12th Jul 2011 at 8:18 pm. |
13th Jul 2011, 5:54 pm | #5 |
Hi Mikey,
Thanks for that info, is it possible to connect tape recorders to it |
13th Jul 2011, 6:30 pm | #6 |
Forgot to mention that I am unable to get any sound from speaker outlets, this cap tests low ESR on my meter so it may be that. see my thread on components & parts section.
Wal |
13th Jul 2011, 7:35 pm | #7 | |
I hope this helps Chris |
13th Jul 2011, 7:56 pm | #8 |
I have connected an amp and speakers, I have sound going into unit but no sound at speakers, if the cap is US does'nt that affect the relays.
13th Jul 2011, 9:16 pm | #9 |
Before connecting a load of kit to it, connect one source, one amp and one pair of speakers
Choose number 1 button in of these for simplicity and select them From memory it uses relays to do most of the switching/routing, you must check the supply for these relays is good and that supply is probably on that cap, so check volts across that. The cap is unlikely to be duff (and isn't, as proved by yourself) and won't be the cause of your problems, of course if there is no supply on it then you've found your problem. As well as having a few of these technics units, I made several shop comparators some 17 years ago for my previous employer, capable of 20 amps and 20 pairs of speakers, lots of cable and lots of relays but they worked fine. I also did an AV version with 5 amps and choice of 5 fronts and 5 centres too. A lot of building required , I remember it well As a very basic check of supply see if you can hear the relays clacking as you change switch positions on the front panel, then dive in with your meter to check further. As for tape decks yes of course you can connect them as sources (ie outputs of them only), any phono plugged source can be used |
14th Jul 2011, 6:38 pm | #10 |
Well folks.
I've cracked it, got everthing wired in and all works well, bit of a brain teaser but got there in the end, but not without your help I must add. Thank you very much. Wal. PS Mikey you should make some more I was offerd £500 for this one. |
14th Jul 2011, 6:45 pm | #11 | |
as mentioned ... I skipped TWO last year !!! and even ripped one of my made ones to bits for the relays a year or some ago £500 Unless you have an absolute shedload of separates they are pretty pointless in the home environment Is it cos they have the technics name on em? |
14th Jul 2011, 6:57 pm | #12 |
Yes I do have a LARGE shedload. the person who made the offer has a HiFi shop.
Thanks for your help. Wal |
14th Jul 2011, 7:03 pm | #13 | |
Won't look as pretty as the technics (large (430mm ish) ally project box with black lid, but it'll do what he wants it to. If they still make those big boxes? size was required co the back panel is riddled with chocolate block |
