27th Aug 2017, 9:15 pm | #1 |
Identification of a vintage radio
Hi
I am new to this and have found a valve radio contained within an old cabinet in my dads lockup. The valves have Marconi and OSRAM markings. I have attached some pictures to help. Is it worth getting working or pass it on for spares? Thank you Martin |
28th Aug 2017, 12:14 am | #2 |
Re: Identification of a vintage radio
How long is a piece of string?
I don't recognise the set except as an interesting relic from the late 1920s. It's missing its tuning/reaction coils from the knob controlled pair of connectors shown in the chassis picture. Perhaps the most interesting find is that mains power unit (HT battery eliminator). Getting it working would be a challenge (how great depends on your skill level in 1920s electronics) and may ultimately be unrewarding in terms of what could be received nowadays. Don't part it out, someone (on here or elsewhere) will take it on if you decide not to keep it!
28th Aug 2017, 11:05 am | #3 |
A homemade set from the mid 20's. It seems to have rheostats for the filaments which were typically used on bright emitter valves but I am not sure they are wired for that. Suitable plug-in coils can be found fairly easily (maybe you already have some).
The transformers are the usual faults on these. You can measure the resistance of the primary and secondary windings to see if they still have continuity. |
28th Aug 2017, 8:37 pm | #4 |
Hi Martin, it looks as if it had a mains power unit (do not use until thoroughly checked out as it could be lethal !). It can be powered by batteries and should almost certainly work when fixed. It is a relatively simple circuit and as another member has said, coils, transformers and connections are your main problem.
Ed |
