Old 26th Aug 2015, 8:52 am   #1
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Exclamation Reducing Hum Pickup by B&O Turntable
A Vibntage B&O Turntable (I didn't make a note of the model no.) was being used with a different make of Amplifier, nessesitating the use of a DIN to phono adaptor lead to connect the TT to the Amp. Some hum was being picked up, which was due to tere being no earth lead on the turntable. To rectify this, I soldered a short length of standard connecting wire to the metal clamp of the DIN Line Socket, then connected this to the earth terminal of the amplifier. Bingo!! Job done without having to open up the turntable and look for a suitable earthing point.
'LIVEWIRE?' is offline
Old 26th Aug 2015, 8:58 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Reducing Hum Pickup by B&O Turntable
This is a common problem with DIN-Phono conversions.
As you've discovered, pin 2 of the connector is generally used as the common ground for the L&R cartridge connections but is NOT connected to the turntable's chassis.
Nick.
Nickthedentist is offline
Old 26th Aug 2015, 10:54 am   #3
'LIVEWIRE?'
I realised that was the case, Nick, but I wondered why B&O didn't fit, as most other tutntable manufacturers do/did, an earth lead. I guess it could be due to the way their TTs connect to other B&O Equipment.
Another thing crossed my mind, which was, and I should know the answer to this, but don't, why is only a thin wire, sometimes up to a couple of metres long, used for TT earthing, when I recall being taught that 'interference currents travel along the surface of a wire, thus, for many applications, a braid about 0.5" wide is used to ground items in order to provide a low impedance path to earth for interference.
Old 26th Aug 2015, 9:26 pm   #4
dseymo1
At mains frequency, the skin effect is all but non-existant, so thin wire is fine. Any RF entering the amp should usually be filtered out by design.
The earth connecton from a turntable sometimes causes more problems than it solves; depending on the power and signal arrangements, earth-loop hum can be induced.
dseymo1 is offline
Old 31st Aug 2015, 10:43 pm   #5
Michael Maurice
Michael Maurice's Avatar
B&O did fit an earth but not to pin 2, instead it goes to the body of the DIN plug.
There are two ways of dealing with it.
Make your own DIN socket to phono but with an extra wire for the earth.
or
Connect pin 2 to the body of the din plug.
Forum Moderator
Michael Maurice is offline
Old 1st Sep 2015, 9:19 am   #6
SeanStevens
SeanStevens's Avatar
I had exactly this problem - till I got the matching Tuner amp to mate to the record player.
I used an extra earth wire I made up between amp and player.
SEAN
There are only 10 types of people, those who understand the binary system, and those who don't.
SeanStevens is offline
Old 1st Sep 2015, 10:18 am   #7
'LIVEWIRE?'
I basically did as Michael Maurice says, i.e., connected an earth wire to the body of the DIN Socket of the DIN-Phono Adapter, though I left the screens of the audio leads connected to pin 2 of the socket. The lead & plug fitted to the deck I left as B&O had wired it. No problems arose from doing it this way
Old 1st Sep 2015, 10:27 am   #8
vidjoman
B & O sold their products as a 'system' and they were all compatible with each other and would not cause earth loops etc. Plug & play is the current term. Using one of their products with other connectors/adaptors often resulted in a problem. They expected you to only buy their products.
vidjoman is offline
