27th Aug 2017, 9:40 am | #21 |
Re: HMV 1122 Capacitor Confusion
Also, the voltage accross R3 (V1 screen) is 100V. The grid voltage on V1 triode section is -0.5V. The grid voltage on the grid of the pentode pin 4 is 0 v.
Failing to prepare is preparing to fail ... |
27th Aug 2017, 9:44 am | #22 |
Annoyingly, now I receive a French station on AM.
27th Aug 2017, 10:12 am | #23 |
OK, both anode tags on V1 base are broken. I have to put in a new B7 base before I can carry on. Riveted in, damn.
27th Aug 2017, 10:39 am | #24 |
With the repaired V1 base I measure 245V. The French station I received earlier on has disappeared. I now suspect a bad contact on the selector switch. This, however, should not explain the high voltages.
27th Aug 2017, 12:41 pm | #25 | ||
Going back to the voltages you reported in post 15.
1] You have made an error measuring the voltages. 2] I have made a misinterpretation of the readings you reported. 3] There really is a 26 volt drop across the primary of both IF transformers. In the case of 3] above you have a fault in the IF transformers. The DC resistance of the IF transformers is very low the order of a few ohms; to get a 26 volt drop there needs to be a number of AMPS flowing, clearly impossible. The only possibility is that the primaries have a high resistance fault that you can check easily with an ohm-meter. Your high HT could be caused by an incorrect mains tapping set-up but it will not cause the receiver section to be dead. |
27th Aug 2017, 11:21 pm | #26 |
Are V1 and V2 fed from a common anode resistor? If so this might have gone high/open.(or de coupler short?) I wouldn't be surprised as those little tubular carbon ones used in that set are prone to this.
I'm not a fan of these particular sets, but given the large speaker I'm sure you're tempted!
28th Aug 2017, 8:48 am | #27 |
For those of you without access to the HMV 1122 circuit the snip below makes things clear.
28th Aug 2017, 9:25 am | #28 |
Hi Stef.
Can you measure the resistance (ohms) across the IF transformer windings all 4 of them. With the set switched off. The manual suggests 5 ohms. |
28th Aug 2017, 11:32 am | #29 | |
My schematics have different voltages! May I ask where you got yours from? The schematics I have I downloaded from this site, together with some service pages. The voltages listed there are different.
28th Aug 2017, 11:34 am | #30 | |
Very strange fault(s) on this set.
28th Aug 2017, 11:42 am | #31 |
I would measure the voltages again to avoid any confusion, measure the voltage on the HT side of the IFT's primary windings and then on the anode side.
Lawrence. |
28th Aug 2017, 2:13 pm | #32 |
Hi Stef.
The voltages on my circuit snip are not those given on the service sheet. They are my understanding of those measured by you and reported in post 15 above. If correct they clearly show there is a 26 volt drop across both IF transformer primaries and indicate a problem with the IF transformers. EDIT: I have just noticed that (in post 30) you have already measured the resistance of the IF primaries and they are OK; it follows therefore that the voltages you reported in post 15 must be wrong. That is good news as it means you haven't got burnt out IF transformers. Try the trick I mentioned with a transistor radio to see if you can find if the local oscillator is working or not. Last edited by ukcol; 28th Aug 2017 at 2:20 pm. |
28th Aug 2017, 2:27 pm | #33 |
Hi ukcl,
Thanks for the tip with the transistor radio, I'll gve this a try ...
28th Aug 2017, 2:29 pm | #34 |
I also dig out my old analog meter just to double check the voltages again. Something is not quite right there.
Regards, Stef.
