11th Apr 2021, 8:15 pm | #1 |
Car stereo Blaupunkt Woodstock SQR88 blown something on installation
Hi all
I was hoping someone could help me, I recently bought a mint Blaupunkt Woodstock/Memphis SQR88 (shipped from Lithuania to the UK which took almost 4 weeks) and after it was working perfectly fine for a few minutes I have stupidly blown something. When testing the auto aerial function, the accessory switched live cable (which I stupidly had exposed) touched the body/case of the radio so shorted out to ground and now nothing displays apart from backlight. Is there a specific internal component that may have blown from this sort of contact? Or have I damaged something more significant? I’ve managed to find and print off a full circuit diagram but if I know what it all means I’m praying it’s an easy fix - Please help!!! Thanks Dan |
11th Apr 2021, 10:44 pm | #2 |
Re: Car stereo Blaupunkt Woodstock SQR88 blown something on installation
Post an extract from the circuit, covering power in, switching and power out. There might be a supply fuse fitted to this radio which will have blown.
Leon. |
11th Apr 2021, 10:53 pm | #3 |
Yes, there's usually a 20mm glass fuse fitted in the back of these, where the power connectors plug in. And this will probably be on the main (Ignition Key= Accessory position) switched supply. So it may only have the backup supply present, which it may power the illumination from.
12th Apr 2021, 12:18 am | #4 |
IMHO the backlight may be driven from the car panel lighting circuit.
Cheers - Martin ZL2MC |
