10th Apr 2021, 7:11 pm | #1 |
Identifying Prototype EMI equipment
Hello fellow Hi-fi nuts!
This is my first post. I have in my possession a rather trendy looking piece of Hi-Fi equipment I’m trying to identify/evaluate. The system belonged to my Grandfather when he worked for EMI back in the day (he was an engineer there). I’m told that a few select employees were “gifted” some prototype equipment and the system I have is one of these “prototypes.” Now I’m not expecting or assuming anything as my hi-fi knowledge is limited...but would any kind person/people be able to tell me what I’ve got and if it has any value? I can tell you that I’ve never heard the system in living memory and that it will need a full and thorough service. ...but in the right hands it would be wonderful for it to live and breathe again! I attach some pictures (yes it needs cleaning!) Thanks for your time Dan PS I have more pictures/serial numbers but am only able to upload 5 pics at a time |
10th Apr 2021, 7:27 pm | #2 |
Re: Identifying Prototype EMI equipment
It looks... "interesting" - but I suspect it's not entirely original.
The amplifier in the bottom part looks like a single-channel one using something like a pair of EL34 in push-pull; the top part - despite the "stereoscope" monicker and CRT, seems to have RCA phono-plugs for its interconnects (which didn't really become a common thing here in the UK until the 1960s) and the chipboard shelf it sits on is ill-at-ease with the outer case. I'd suspect that this is a 'bitsa' - blending an early rather-lush outer case with a mid/late-50s single-channel [though potentially-fruity!] amp and a 60s upper lump. See here: http://tubeintegratedamplifier.com/h..._amplifier.php HMV 555 Stereoscope. Seems it has its own inbuilt amps using EL84s - so what is the big EL34-esque amp in the bottom of the cabinet doing? Last edited by G6Tanuki; 10th Apr 2021 at 7:33 pm. |
10th Apr 2021, 7:33 pm | #3 |
The Stereoscope bit is apparently from 1959.
10th Apr 2021, 7:36 pm | #4 |
Also see this thread: https://vintage-radio.net/forum/showthread.php?t=111233
Seems they were actually made by Clarke&Smith. |
10th Apr 2021, 7:38 pm | #5 |
HMV Stereoscope.
PA, very similar to a STD373/DLS. I can hear someone going ka-ching already. Lawrence. |
10th Apr 2021, 7:39 pm | #6 |
From Jonathan Hills book
10th Apr 2021, 7:48 pm | #7 |
There is a "Model No. STDx?x?x?" on the amplifier chassis but it also says 117 V.
George |
10th Apr 2021, 7:57 pm | #8 |
The dust pattern in the speaker fret shows the shape of the EMI 13.5 x 8 inch elliptical driver.
10th Apr 2021, 8:03 pm | #9 |
The presumed back of the Stereoscopelooks like a later Japanese amp - the flat pin mains outlets were unknown in the UK until the mid-60s.
10th Apr 2021, 8:10 pm | #10 | |
Clearly some US design cross-pollination going on here! |
10th Apr 2021, 8:12 pm | #11 |
Guys thanks so much for the flurry of replies, so swift! I’ll post a few more pics
Keep the info coming if you’ve got more! So I think the turntable (which I’ve not photographed as I can’t find the blasted key to the lid!) was changed to a Garrard Model 301 transcription motor. I also appear to have the instruction manual to that and even an inspection card! Thanks so much for your assistance, it is greatly appreciated. Dan |
10th Apr 2021, 8:15 pm | #12 |
Yes, the back does indeed look 10+ years too new. Puzzling!
The phono leads look newer still, perhaps mid 70s, not that that affects the amps, of course. |
10th Apr 2021, 8:21 pm | #13 |
The rear has Type No 55 something on it so far as I can make out.
Lawrence. |
10th Apr 2021, 8:36 pm | #14 |
It looks like type 556
Cheers Mike T
10th Apr 2021, 8:47 pm | #15 |
10th Apr 2021, 9:11 pm | #16 |
The EPU 100 enjoys cult status these days, as does the 301, but it isn't a very capable pickup by modern standards, and servicing could be tricky - you could try the Expert Stylus Co.
10th Apr 2021, 9:18 pm | #17 |
The spade mains connectors and phono sockets were in widespread use on hi-fi amps of the period such as Leak, Beam Echo and so on. The phono sockets are a pest as the modern molded types do not fit in adjacent sockets as the original leads were metal plugs with no cover.
10th Apr 2021, 9:36 pm | #18 |
I have seen one of these before, same Stereoscope pre-amp, cabinet, etc, and curiously that was also in Cheltenham. It belonged to a friend, who had inherited it from his father (who had worked for EMI, I think). I wonder if it's the same one...?
Mike |
13th Apr 2021, 12:50 am | #19 |
I think the DLS designations on the speakers suggests they're intended for the U.S. market.
Regards, Paul
...No, it's not supposed to pick up the World Service, it's not a radio! |
