8th Apr 2021, 11:03 am | #1 |
Lamp limiter bulb question.
Is it recommended to use one to test a solid state tape recorder which has not been used for a while - just in case?
It has a 160ma, fuse so would a 40watt bulb be appropriate? |
8th Apr 2021, 12:07 pm | #2 |
Re: Lamp limiter bulb question.
My answer would be yes - provided the equipment is old enough not to have a switched mode power supply (SMPS). SMPSs can have odd properties when the input mains voltage is well below the nominal working voltage. I would have thought that a 40 Watt bulb would be alright, Just bear in mind that motor operation (eg play, rewind etc) will draw more current...
8th Apr 2021, 2:31 pm | #3 |
You could probably use a much lower wattage bulb to start with, as sold-state tape recorders probably only draw a few Watts - hence the low 160mA fuse.
60W / 100W bulbs were often used for more power-hungry devices, and often used to diagnose TV SMPSU faults, to stop it all going bang at switch-on and taking the 3.15A fuse out. The main smoothing capacitor in most tape recorders, will be quite small & low voltage, and probably find that reforming with these isn't generally necessary as much less susceptible to breakdown and leakage as HV ones in vintage equipment. Probably more likely for capcitor to dry-up and be open circuit, plus small transformer in these will limit current from being too massive But no real harm in having a bit extra extra surge-limiting to start with, rather than the fairly-low 160mA fuse blowing (Might still do, with a 40W bulb if there was a severe overload). |
9th Apr 2021, 8:08 pm | #4 |
Thank you
I tried the 40watt bulb limiter, I also tested the filter caps for esr. Luckily switch on was fine. Mind you it didn't work at first but i fixed the fault, there was a bodged repair hiding in wait! |
