Old 8th Apr 2021, 1:11 pm   #1421
ScottishColin
Default Re: Non-working Commodore PET 3016
OK - new EPROM has arrived. I have replaced all other original ROMs and put the new Sloth_Vc EPROM in the adapter previously provided. Plugged it in and I still get zero page error - stopped.
What testing would be next?
Colin.
ScottishColin is offline
Old 8th Apr 2021, 1:16 pm   #1422
SiriusHardware
That behaviour is as expected, the new difference is under the bonnet, where the code should now keep on trying the write to zero page / read from zero page operation which failed.
To verify that, look first for continuous waveforms on the read and write enable pins (pins 1 and 19) of the buffer ICs UE9 / UE10 after the 'Stopped' error message has appeared.
SiriusHardware is offline
Old 8th Apr 2021, 2:04 pm   #1423
ScottishColin
Continuous waveforms on all four pins - see attached.
Colin.
Name:	Pin 1 UE9 20210408.jpg
ID:	231205   Click image for larger version
Name:	Pin 1 UE10 20210408.jpg
ID:	231206   Click image for larger version
Name:	Pin 19 UE9 20210408.jpg
ID:	231207   Click image for larger version
Name:	Pin 19 UE10 20210408.jpg
Old 8th Apr 2021, 2:41 pm   #1424
ortek_service
ortek_service's Avatar
These all look fine (although a definitive check would be to have pin1 on 1 channel and pin 19 on the other, as you could then see that one is exactly the inverse of the other).
You could try 'scoping all the remaining (other than Power & ground) pins on UE9 & UE10 (16 pins on each) to see if any look on each side of the buffer look substantially different from the majority of the others As when stuck in this loop, with 55's / AA's being written / read (if working), then they should all look very similar - particularly on the 'memory-bus side', although 'CPU Data-bus side ones' will probably look a bit different due to Diagnostic ROM reading etc.
In theory, you only need to probe 4 pins on the 'CPU Data-bus side' and 4 pins on the 'Memory-bus side' data in/out, on each of the UE9 & UE10 IC's as they are joined together in pairs
- but no harm in checking all just in case there's a connection issue on sockets / tracking etc.
This may be easiest to start with, as to work out exactly what's happening involves looking only at these when the signal on the UE9/10 Pin19's is low.
ortek_service is offline
Old 8th Apr 2021, 3:20 pm   #1425
ScottishColin
Here's the comparisons as per your post.
In terms of the rest of your post - do you mean that the equivalent pins of UE9 and UE10 should look the same?
Colin.
Name:	Pin1 UE10 yellow pin 19 UE9 green 20210408.jpg
ID:	231218   Click image for larger version
Name:	Pin 1 UE9 yellow pin 19 UE10 green 20210408.jpg
Old 8th Apr 2021, 3:52 pm   #1426
ScottishColin
OK - assuming that UE9 and UE10 pins should have the same waveforms, see attached. UE9 and UE10 pins 5 & 6, UE10/7 and UE10/13 look odd to me.
Colin.
File Type: pdf UE9 yellow UE10 green comparisons - 20210408.pdf (215.0 KB, 44 views)
Old 8th Apr 2021, 4:03 pm   #1427
ScottishColin
OK - rebooted and tested again with differing results. Is it possible that different code is being executed?
On screen I have a slightly different error message
o pak page error - stopped
Colin.
Old 8th Apr 2021, 4:17 pm   #1428
ortek_service
I was only thinking of concentrating on UE9 & UE10 buffers for now
- As you can't directly compare what's there with the other buffers as the RAM access is split into Screen RAM or Main RAM on those (some of who's buffers you've already replaced - migt be useful to remind us which of these have actually now been socketed / replaced / checked OK. And easiest to look at things that are common, being as both RAM areas don't seem to read back correctly)
And best to try and work out if signals on UE9 & UE10 do appear to be all OK first, before moving to other areas - I'll have a look at the ones you've captured.
Regarding the intermittent corruption of the displayed message:
It can't really be different code being executed, but could be corruption / something 'floating a bit on the bus - most likely on screen RAM access
But I think that's probably best looked at later, as it's difficult to pin-point if intermittent and could be related to what's wrong with the RAM accessing.
Old 8th Apr 2021, 4:49 pm   #1429
NivagSwerdna
Long thread... and I have a poor attention span...
Did the 74S74 at H1 get replaced?
NivagSwerdna is offline
Old 8th Apr 2021, 5:00 pm   #1430
ScottishColin
Yes it did.
here's the compete list of replacements so far....
UB2 - new socket new IC
UB3 - new socket new IC
UC3 - new socket new IC
UC4 - new socket
UD7 - new IC
UD9 - new socket
UE7 - new socket new IC
UE8 - new socket new IC
UF7 - new socket new IC
UF8 - new socket new IC
UF9 - new socket new IC
UG5 - new socket new IC
UH1 - new socket new IC
UH3 - new socket new IC
UH6 - new socket new IC
So much for me wanting to retain original parts....although it's fair to say all of the above were tested and failed tests.
Colin.
Old 8th Apr 2021, 5:01 pm   #1431
ortek_service
Colin.
Thanks for those - even though they show Pin 1 on one IC and Pin 19 on the other other, the two IC's Pin 1's & Pin 19's do connect to each other. So should get the same results (providing there's no broken connections).
And both of these show that either Pin 19's are always inverse of either Pin1's, and so all are connected OK.
Regarding the rest of my post, I really meant (but I hadn't had chance to look at schematic) that all 'Memory bus side data lines' on both IC's should be very similar, when stuck in diagnostic zero-page failure infinite loop. i.e.
UE9 Pins: 18/17, 16/15, 14/13 & 12/11 and UE10 Pins: 18/17, 16/15, 14/13 & 12/11 (where ones connected either side of '/' are joined together so shouldn't matter which one is probed, if PCB tracks are all OK)
The 'CPU Data-bus side' of UE9 & UE10, won't always look quite the same, as there's sometimes reads from the Diagnostic ROM on these (so can only compare exactly when UE9 or UE10 Pin19's signal is Low - for read from RAM)
But for reference, these are:
UE9 Pins: 2/3, 4/5, 6/7 & 8/9 and UE10 Pins: 2/3, 4/5, 6/7 & 8/9 (where ones connected either side of '/' are joined together so shouldn't matter which one is probed, if PCB tracks are all OK)
A >= 3Ch 'scope / v.cheap USB logic-analyzer is ideally what's required to look at the CPU-side signals, as that allows triggering / viewing in the right places.
Old 8th Apr 2021, 5:14 pm   #1432
Mark1960
Yes it did.
UC4 - new socket
UD7 - new IC
UD9 - new socket
Colin.
List doesn’t include UH1
Mark1960 is offline
Old 8th Apr 2021, 5:19 pm   #1433
ortek_service
Colin.
Yes, I've just had a glance through these and found a few lines with either no activity (so stuck high / low) and some with a lower amplitude - so a bus conflict or a a very weak output drive.
I'll have a bit more detailed look, to see exactly which ones these correspond to.
But I am thinking we should be able to find what might be happening here.
Old 8th Apr 2021, 5:19 pm   #1434
ScottishColin
Does now - just edited it as I realised my error.
Colin.
Originally Posted by Mark1960 View Post
Yes it did.
UC4 - new socket
UD7 - new IC
UD9 - new socket
Colin.
Old 8th Apr 2021, 5:20 pm   #1435
ScottishColin
The second set of traces look a lot more healthy though...
Colin.
Colin.
Old 8th Apr 2021, 5:29 pm   #1436
ortek_service
Colin.
Colin.
I thought the second set were when you got a slightly-corrupted Error message? - In which case, it's odd they were better
I wouldn't really expect any difference, if the diagnostic firmware was stuck in the same endless loop executing the same write / read which I presume will always be at first RAM location (but that or readback value mismatches are not currently attempted to be written to screen)
Old 8th Apr 2021, 5:29 pm   #1437
PJL
The 1st test shows UE9/5 and UE10/5 as both being continuous 0. If the program were running correctly this should not be possible as the data being written is A5/5A so all CPU data pins should be changing.
The 2nd test looks very unhappy with lots of noise. UE9/5 now fluctuates but UE10/5 shows possible bus contention. The bus contention also seems evident in UE10/3.
Is it worth looking at the PSU and any rail decoupling capacitors as a possible source of intermittent behaviour? I am not sure we can trust the results of the test program as it stands.
PJL is offline
Old 8th Apr 2021, 5:37 pm   #1438
Mark1960
Looking at plots in #1426 and #1427, I think there was some confusion with instructions on what to check.
Only pins 1 and 19 are the same between UE9 and UE10.
Some of the plots for UE10 pins look bad, showing bad logic levels. I think it would be good to check further as it might only be UE10 that needs to be replaced.
I’ll list the pairs of pins to compare in the hope we avoid confusion this time.
UE10-3, UE10-18
UE10-5, UE10-16
UE10-7, UE10-14
UE10-9, UE10-12
UE9-3, UE9-18
UE9-5, UE9-16
UE9-7, UE9-14
UE9-9, UE9-12
If you could put in pdf that is easier to review.
After we see those plots, if there are still problems on UE10 pins, we can compare those bad pins with pins 1 and 19 to confirm if the buffer is the cause, I’ll describe in more details when we see the plots for the above pairs.
Mark1960 is offline
Old 8th Apr 2021, 6:11 pm   #1439
ScottishColin
Ah - I guessed wrong. Apologies.
See attached PDF for results.
Colin.
UE10-3, UE10-18
UE10-5, UE10-16
UE10-7, UE10-14
UE10-9, UE10-12
UE9-3, UE9-18
UE9-5, UE9-16
UE9-7, UE9-14
UE9-9, UE9-12
File Type: pdf Post 1438 - UE9 and UE10 - 20210408.pdf (244.5 KB, 43 views)
Old 8th Apr 2021, 6:28 pm   #1440
Mark1960
So UE9 looks ok, but UE10 looks bad on pins 3 and 5.
Just to be certain compare the following pairs.
UE10-3, UE10-19
UE10-5, UE10-19
If the incorrect levels on pin 3 and 5 match the time pin 19 is low then this confirms UE10 is at fault and not some other chip in the system.
Mark1960 is offline
