4th Apr 2015, 12:02 am | #1 |
3 interesting switches
In a box of many bits from a gentleman who kept everything from the war onwards, were 3 assorted interesting switches.
A Sunvic Simmerstat - From a heater? 16 Amp 250 volt clockwork timer switch - "Crater, England" Chunky Bakelite switch from a heater of some kind. Still satisfyingly clunky in operation! Any idea what they came off? And are they any use to anyone? |
4th Apr 2015, 2:52 am | #2 |
Re: 3 interesting switches
The bakelite plugs and light socket fittings:
4th Apr 2015, 8:22 am | #3 |
Simmerstats were (are?) the usual method for controlling 'radiant ring' hobs and the like.
The timer is most likely from something like a tumble dryer. What's its maximum 'on' time? Not sure about the third switch, which is rather more specific - someone will probably reconise it though. |
4th Apr 2015, 9:05 am | #4 |
Have you been rummaging around in my cellar? I've quite a few of those plugs, etc. in a box down there! The Simmerstat was indeed used in many electric cookers. I also have one one which is incorporated into a 13amp plug. The switches look as if they may be from a very old hairdryer. Just a thought. Cheers, Pete.
4th Apr 2015, 10:55 am | #5 |
The dual switch is from an 'Ormond' E1022 or equivalent hairdryer.
Ormond E1022 at MoDiP There are a couple of unusual items in that box Pete! |
4th Apr 2015, 11:11 am | #6 |
The second one reminds of the mechanical type used in early tumble dryers, great ticking sound, in the box there is heat control knob and that might have been of a Burco tumble dryer
Gary |
4th Apr 2015, 12:28 pm | #7 |
You can still buy the clockwork timers, they're used in Dualit toasters and garage battery chargers. Ditto simmerstats, still used in cooker rings and I recently bought one for a plate warming cabinet for a restaurant.
Kevin |
4th Apr 2015, 12:29 pm | #8 |
If there's anything you want out of the box for your museum, Lucien, you can PM me. Cheers, Pete.
4th Apr 2015, 1:41 pm | #9 |
I remember most of those from the time I started work, 13a plugs were only just beginning to be installed and in our area they were the round pin type with the live one being the fuse. We used the 2 pin 5a Clix plug in your picture for most things.
Peter |
5th Apr 2015, 8:26 am | #10 |
There is a few in your box I have not got in my collection Pete.
Regards Robin |
6th Apr 2015, 12:00 am | #11 |
Thanks everyone, the depth and the variety of knowledge on here never ceases to amaze me!
6th Apr 2015, 1:48 am | #12 |
If you carefully open up the Simmerstat, you will find it contains a miniature heating element with its own bimetallic thermostat. That is switched with the load (normally, a cooker ring) so the hotter the internal heater has to get to satisfy the thermostat, the longer the external device will get supplied with power. When the thermostat opens and the internal heater goes off, it will begin to cool down again; during which time, no more energy is supplied to the external device.
A clockwork timer from a tumble dryer will usually have two sets of contacts. In a tumble dryer, the fan usually runs alone for the last 5 or 10 minutes of the drying cycle, to cool the machine and clothes down to a safe temperature. So the contacts which are meant for the heating element will open 10 minutes before the contacts which are meant for the fan and drum motor open at the end. You can determine which is which, using a multimeter and winding up the timer in small increments to just past the point where the heater contactsx. Both sets of contacts will be good for several amperes, as it was usual to wire the "heater" contacts in series with the "motors" contacts so the heater could not come on unless the fan was blowing.
