Old 6th May 2019, 9:49 pm   #1
Johnbarn
Default Hacker Herald noisy
My LW/MW Hacker Herald has developed a noisy output as if someone was blowing across the studio microphone. I thought it might be a bad contact at the 5pin plug or the wave change switch or even the volume or pots for bass and treble but gentle cleaning and contact cleanser hasn’t helped. Can anyone help me in looking further? The radio is receiving all stations normally but just has this annoying rumble in the background which can only be minimised by winding the bass back fully.
Johnbarn is offline
Old 6th May 2019, 10:31 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Hacker Herald noisy
Does the noise vary with the volume control or is it at a constant level?
paulsherwin is online now
Old 6th May 2019, 10:32 pm   #3
martin.m
martin.m's Avatar
The problem is almost certainly caused by transistor T1 on the bottom audio panel. A BC108 can be used as a replacement.
Post crossed with Paul's
Regards
Martin
martin.m is offline
Old 6th May 2019, 10:38 pm   #4
Johnbarn
The noise is constant and not dependent on volume setting.
Thank you to both Paul and Martin. I’ll source another BC148 or a BC108 as you suggest.
Johnbarn is offline
Old 6th May 2019, 10:44 pm   #5
paulsherwin
Don't use another BC148 Lockfit. Use a different BC108 family transistor like a BC548. This is just a general purpose transistor and lots of other types will also work - 2N2222, 2N3904 etc.
https://en.wikipedia.org/wiki/BC108_family
Lockfits are commonly failing now and a forum search will find lots of threads about them.
Old 7th May 2019, 11:22 am   #6
Andrewausfa
Andrewausfa's Avatar
Which Herald is it? RP10, RP30 or RP35?
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 7th May 2019, 8:19 pm   #7
Johnbarn
Andrew, it’s a MW/LW Herald RP35 and thanks to Paul and Martin’s advices I have replaced T1 with a BC108 and it now sounds great!! Just the way a Hacker should. Thanks boys.
Johnbarn is offline
