8th Oct 2018, 10:49 am | #21 |
Re: Gold Radio Station
If you are hearing the Punjabi station on 1584 then the oscillator is unlikely to need adjustment. You are simply outside the service area of the Gold transmitter. This isn't a surprise as the Gold AM network has been cobbled together from various old ILR local transmitters and there are big coverage gaps. There is no coverage here in Oxford, for example, though weak signals can be received from a couple of out of area transmitters.
8th Oct 2018, 11:15 am | #22 |
I have felt like suggesting to the OP to get a decent radio, Fidelity were very much the low end of the budget range, and there doesn't seem to be much information on the RAD24.
Mike |
8th Oct 2018, 11:19 am | #23 |
Here's an early example of the same problem: https://www.radios-tv.co.uk/the-year...-pocket-radio/
8th Oct 2018, 11:25 am | #24 | |
https://www.radiomuseum.org/r/fidelity_rad24rad_2.html |
8th Oct 2018, 5:31 pm | #25 | |||
8th Oct 2018, 5:50 pm | #26 |
What's the highest frequency medium wave station you can receive at present and where does it appear on the dial?
8th Oct 2018, 6:31 pm | #27 | |
Or are they the same? In case they are the same. This is the highest (?) i can get. Its got a bad interference however |
8th Oct 2018, 6:36 pm | #28 |
Radio waves travel at 300,000 kilometres per second.
So to convert wavelength in metres to frequency in kilohertz, or vice versa divide the value into 300,000. 200 metres is 1500 kHz. 200kHz is 1500 metres.
8th Oct 2018, 6:40 pm | #29 |
Set the pointer at the low frequency end of the scale ie below 200 metres. If there's no station there advance the tuning until you receive one. Listen to the station until it identifies itself. Google the station to find out its medium wave frequency in your area. Convert the frequency to wavelength and see how it compares with the pointer setting.
8th Oct 2018, 6:49 pm | #30 | |
Thanks |
8th Oct 2018, 6:54 pm | #31 |
Lyca Radio is on 1458 kHz which is 206 metres.
Gold Radio is on 1548 kHz which is 194 metres. So you have a dial calibration error which could simply be the pointer being in the wrong place relative to the tuning capacitor. Is there further movement available towards the high frequency end of the scale?
8th Oct 2018, 6:57 pm | #32 |
It stops dead here.
(Sorry for the poor quality photo) Thanks |
8th Oct 2018, 7:02 pm | #33 |
That's the wrong end of the scale!
Your scales are marked in metres. Shorter wavelength (200 metres) means higher frequency. Longer wavelength (550 metres) means lower frequency.
8th Oct 2018, 7:05 pm | #34 |
Did you identify that station? Could it have been Punjab Radio on 1584kHz 189 metres?
8th Oct 2018, 7:06 pm | #35 | |
This is how far it goes higher frequency. Thanks |
8th Oct 2018, 7:13 pm | #36 |
If there are no stations receivable below Lyca Radio on 206 metres, then either you're in a poor signal area or you're going to have to adjust the radio as described in posts #10 amd #11.
8th Oct 2018, 7:34 pm | #37 |
Oh OK, I'll test with another radio if possible and then I'll sort something out.
Thanks for your help! |
8th Oct 2018, 8:36 pm | #38 |
None of my circuit CD show a RAD24. I found a RAD23 and a RAD26, Both of these have FM as well so the RAD24 may be a scaled down version of either of these. The 23 and the 26 have MW listed as 186 - 550 metres so there is no reason to suspect that the RAD24 should be any different, in which case it seems that the local oscillator needs a tweak.
8th Oct 2018, 8:40 pm | #39 |
What is the oscillator and how do I tweak it to get gold radio?
I have no idea what im doing otherwise... Thanks |
8th Oct 2018, 9:14 pm | #40 |
This page gives the information about local oscillators and mixers.
https://www.vintage-radio.com/repair...rf-stages.html
Frank |
