Old 19th Mar 2018, 2:04 pm   #21
dj_fivos_sak
Default Re: Ferguson Videostar FV31R Repairs
I've never seen this chassis before. Interesting. On the power supply side of things, change the caps that are located on the secondary DC (cold) side, which is after the transformer. That power supply looks weird too. What are those IC in there for?
dj_fivos_sak is offline
Old 19th Mar 2018, 4:13 pm   #22
Welsh Anorak
Welsh Anorak's Avatar
I'll have a look for the schematic - I should have one.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 19th Mar 2018, 4:45 pm   #23
winston_1
Originally Posted by qsilver View Post
Ah, good to know that the battery is just for channel storage. .
It isn't. It is for the clock.
winston_1 is offline
Old 19th Mar 2018, 9:42 pm   #24
whiskas
whiskas's Avatar
Just a little info to add from my knowledge of the confirmed JVC FV- Ferguson vcr's:
The JVC's were: FV10B, FV11R, FV12L, FV13H, FV14T, FV20B, FV21R, FV22L, FV26D, FV33H, FV37H, FV39S (S-VHS), FV43H, FV44L, FV46T - I think that's all of the JVC FV's.
It's somewhat confusing that the FV31R & FV32L are sandwiched inbetween those JVC numbers but were infact made by Thomson..!
whiskas is offline
Old 19th Mar 2018, 11:16 pm   #25
dj_fivos_sak
Great info. That's why I got confused and thought the FV31R was a clone of the JVC HR-D170.
Old 19th Mar 2018, 11:44 pm   #26
jayceebee
jayceebee's Avatar
Other JVC based machines were the FV57H, FV58T and FV59S.
The deck used in the FV31R was I believe manufactured by Moulinex.
John.
jayceebee is online now
Old 20th Mar 2018, 1:31 am   #27
Maarten
Might be a Toshiba deck as Thomson also made Toshiba branded videos. Moulinex video decks (coffee grinders) were made by Philips, called Charly
Maarten is offline
Old 20th Mar 2018, 1:52 am   #28
whiskas
whiskas's Avatar
How could I forget the FV57H - I have one.. derrrr!
whiskas is offline
Old 20th Mar 2018, 11:05 am   #29
dj_fivos_sak
Yeah. I have a Grundig with a similar U-loading mechanism. Betamax copycats...
Old 21st Mar 2018, 1:17 am   #30
McMurdo
McMurdo's Avatar
I remember that hideous range of machines. I recommended my auntie bought her first video recorder as a Ferguson, unfortunately she came back from Argos with one of those Thomsons. It led a short and sheltered life but descended like yours into comets..definitely not head wear as it was seldom used. I took it in to look at (all that MELF SMD!!) . It was definitely not tracking properly as shown by the head envelope, cleaning the guides and blocks didnt help and in the end I gave up, putting it down to the tension band or something. She put it back under the telly as she'd grown to like the big clock.
It was replaced by a supermarket model when they started doing them.
Kevin
McMurdo is offline
Old 21st Mar 2018, 3:49 pm   #31
Welsh Anorak
Hi
Sorry - I was sure I had an FV31 manual but it turned out to be a 3V31! Oops...
Glyn
Old 21st Mar 2018, 4:20 pm   #32
Maarten
Not quite, Grundig likely adapted their own VCR deck design. Also Betamax copied the design from U Matic. VCR was realised around the same time as U Matic, hard to say whether Philips copied Sony or the other way around or neither. The Charly deck seems to have been created out of thin air, it doesn't really look like any earlier or later design.
Maarten is offline
Old 22nd Mar 2018, 8:09 pm   #33
qsilver
Thanks for looking for the manual Welsh Anorak, I appreciate it. I can replace them as I go along instead.
Is it as simple as, the high voltage mains side is under the plastic cage?
and about the SMD.... yes, that's odd. At some point I found a resistor has come loose from somewhere. It seems to be working without it and I cannot see where it came from... it was in the bottom of the machine. I don't know if it's happened while I've been working on it or if it had dropped off previously.
qsilver is offline
