2nd Dec 2016, 11:01 am | #1 |
Problem loading tapes with Sanyo VTC-9300PN
Hello! I've come across your forum in the hopes that you could help me with a problem.
I've unearthed a PAL version of the VTC-9300PN and was trying (hopefully) to digitally convert some Beta tapes. Instead when I insert any tape into the unit it fails to load properly and results in a continuous clicking sound (video here). I imagine its a problem with a dodgy belt as they're usually the first things to fail, espically in a near 30+ year old machine. Help of any kind would be greatly appreciated! Thank you |
2nd Dec 2016, 8:51 pm | #2 |
Re: Problem loading tapes with Sanyo VTC-9300PN
First port of call for an old machine like this is the belts and idler. I'm pretty sure you can get them on eBay. If you're competent at replacing them then fire on. But don't go using any of your good tapes on the trial runs.
Good luck |
2nd Dec 2016, 11:55 pm | #3 |
Hi. Open up the bottom cover, open up the big W2 circuit board (it's held in hinges for ease of service) and check:
1. Capstan belt (picture 1) 2. Loading/unloading tyre of capstan flywheel (picture 2) Regards Fivos Last edited by dj_fivos_sak; 3rd Dec 2016 at 12:01 am. |
3rd Dec 2016, 12:35 am | #4 |
Tip: Stretch a normal rubber band over the top of the existing belt(s). Often that's enough to get the machine working until you can source the proper replacements.
Regards, John |
3rd Dec 2016, 1:13 am | #5 |
It will work but there will be a lot of wow and flutter since there's no capstan servo control on this machine.
3rd Dec 2016, 2:32 am | #6 |
Thanks for the tips! I'll open the bottom cover as soon as I can and report back. This restoration is a bit special since a lot of these tapes were recorded by my late grandparents Betacam. Unfortunately that's out of action as well as the service light turns on.
3rd Dec 2016, 10:58 am | #7 |
The Sanyo 9300 belts are still available through SWL Electronics Epsom, Surrey KT19 0DT. Tel 0208 393 7774 Contact Malik Baround. They are advertised on eBay.uk which you can access via your eBay.au account as follows:
Search the UK site and open the advert. You will not be able to save it to your watch list because the uk site won't let you but, hey presto, it will be seen amongst recently viewed items on your eBay.au account. You can then click on the item and order it and if necessary, contact the supplier for postage rates if not shown. Lastly, in my experience, the Sanyo 9300 isn't the best at squeezing out the best from Betamax recordings and slight adjustment to the "expansion" pot will help. Best of luck Chris nee Simpsons |
3rd Dec 2016, 2:52 pm | #8 | |
Fivos |
3rd Dec 2016, 5:51 pm | #9 |
As said above, If you're looking for decent picture and sound You would be better sourcing a decent Sony or a vtc-5150 rather than going to any trouble repairing the one you have, youl find yourself a bit disappointed at the end of your troubles.
3rd Dec 2016, 6:12 pm | #10 |
The VTC 53xx and 54xx have a better quality than the 5xxx and 51xx models. I have compared my 5000 with my 5350 and the 5350 gave a little better results.
4th Dec 2016, 6:15 am | #11 |
Well, I've take off the bottom and have both good and bad news.
The Good: You can playback a tape by manually turning the head to load them. I replaced one of the belts with an elastic band. The Bad: Unfortunately some of these tapes are stuffed, being that they were stashed in a closet in a seaside town. There's one good one so far (which is the most important one to convert, thank god), but the others I'm not so sure if they can hold up. Anyway, you've all been a great help and I've only got one more question. I've identified that the BNC video-out can be converted to a composite signal, but what of the audio out? I can't identify the type of plug it is or if it can be converted to a mono RCA plug. Any help here would be greatly appreciated. Thanks again! |
4th Dec 2016, 1:07 pm | #12 |
The audio in / out on these machines is just a standard 5-pin DIN connector. Pins 3 and 5 are both "out", 1 and 4 are both "in" and pin 2 is the common.
4th Dec 2016, 3:58 pm | #13 |
Video in/out: PL-259 (Aka UHF connector)
Audio in/out: 5-pin DIN Good luck. |
5th Dec 2016, 12:41 pm | #14 |
Just soldered a DIN to a pair of RCA plugs, so now the sound is working alongside the BNC to RCA plug. Again I have to thank all of you here, I probably never would have gotten so far without your help. But, I do have two more questions.
I'm looking for a good composite to USB recorder to digitise the tapes, and I was wondering if there is a specific model you could recommend. It would be a BIG plus if it could support Linux OOTB, so I could just convert using VLC, ffmpeg or through other programs. Secondly, I've noticed that when you turn the Sanyo completely off and on again, the picture will track fine unless you remove and insert 3 or more tapes. By then the picture goes completely nuts and only comes good by turning it off again. So instead of the tapes playing up (like I stated before) it seems it is just the player. My question is this: Will this problem creep up when digitally converting over long periods of time, or should I be fine to just let it play? |
5th Dec 2016, 1:54 pm | #15 |
Really I'd look for a better machine, somewhere on your local 'freecycle type' website or e-bay there will be someone with a decent machine. As said above the smaller, lighter VTC 5000 series are much more reliable and better picture quality OR a Sony machine but I'd stick to their front loaders and make sure it's a 'go-er' before parting with any significant money. I'm not trying to be unhelpful but, honestly, the 9300 was a really rubbish machine even in its day.
If the material on the tapes is important it's worth getting it right - it may be the last chance you'll get to save them. |
5th Dec 2016, 6:49 pm | #16 |
If you plan on getting a Sony, Avoid the 710 chassis machines (C5-C8) and look for a decent 711 chassis front loading. The older machines are harder to work on and are much heavier and most of them have servo capacitor problems.
