27th Dec 2016, 5:40 pm | #1 |
U502 first cap. change
Hello, before I start on the change of C44 in my Murphy U502 (the cap. to change) there is a query on the voltage rating. The parts list specifies 500v but I have to hand a red Wima mks 4 rated at 400v. Would this be ok to use? Thanks for any replies. David.
27th Dec 2016, 5:45 pm | #2 |
Re: U502 first cap. change
Hi, I don't have the circuit to hand but can't imagine there being any problems with using a 400v rated cap in this set as a decoupling cap. If it needs to be connected across the mains then you'd ideally need a X2 rated cap. Hope that helps.
Thanks, Peter |
27th Dec 2016, 6:07 pm | #3 |
Hi David
C44 is the grid coupling capacitor for the output valve according to the Murphy service information. As the HT on this set is less than 200V I would be happy to use a 400V cap in this position. Cheers Mike T
27th Dec 2016, 6:43 pm | #4 |
Thanks Mike T for the prompt reply. I can see what you mean, it's something that I hadn't thought to look at. david
27th Dec 2016, 6:57 pm | #5 |
I think you will find that on the U502 Murphy have used a ceramic "dog bone" capacitor in this position. If so, it will be very unlikely to need replacement.
Leon. |
28th Dec 2016, 1:57 pm | #6 |
it is tubular with a clear sleeve and TCC type cp335 on it.
David. |
28th Dec 2016, 6:18 pm | #7 |
Leon, could you describe the 'dog bone' cap a bit better. Would it be basically tubular?
If so that might be what I have. David |
28th Dec 2016, 7:08 pm | #8 |
What your describing sounds more like a Metalmite capacitor like the first picture.
The Dogbone ceramic is more likely to look similar to the second picture, A lot of Metalmites are getting tired now but still worth checking, Cheers Mike T
29th Dec 2016, 8:49 am | #9 |
i was worried when you said you were going to fit a Wima, but the worries went away when I saw that it was a polyester type,
29th Dec 2016, 8:27 pm | #10 |
Thanks for the information on the Metalmite and the Wima catalogue. It is a Metalmite and I will check it further before deciding whether to change it.
David. |
1st Jan 2017, 4:54 pm | #11 |
Hello, I have now changed 5 Hunt caps., 2 of which showed some cracking in the sides. Also the Plessey can with the 50 + 50 has been disconnected and 2 seperate 50's mounted under the chassis. As an ex Plessey man I wanted to leave the original, I know that is best anyway. My next question is about c41. Should I change it just because it is an electrolytic or leave it to see if it is a problem?
David |
1st Jan 2017, 5:03 pm | #12 |
It's across the FM discriminator, those electrolytics can be problematic in receivers of that age, I would replace it.
Lawrence. |
2nd Jan 2017, 9:49 pm | #13 |
OK, I have now replaced c41 with a new electrolytic so that's finished my planned replacements. I did notice the polarity of the capacitor and copied it.
David |
