7th May 2019, 12:46 pm | #1 |
Help with identifying an old valve Rambler
Hi old radio fans,
I am a newbie here and know little about old radio sets, so while I've read the FAQs ect. apologies for any faux pas. My other half has inherited some old stuff from her family home, amongst which was a rather anonymous beige box with old fastenings. I opened this up yesterday and it is an old portable radio, with the name "Rambler", it has an access panel underneath with a circuit board containg a mix of small valves and chunky transisters. This still has batteries attached and despite being left switched on these don't look like they have caused damage. I've had a Google but the only Rambler radios I could see looked like 70's/80's Roberts radios - this one looks at least 20 years older. Can anyone tell me anything about it? Is this going to be an easy restore? I have basic physics/electronics knowledge and can use a soldering iron. I'll try and post some pics although this may need to wait until my registration has been approved. Thanks in advance for any info. |
7th May 2019, 1:12 pm | #2 |
Re: Help with identifying an old valve Rambler
Pictures should allow easy identification.
It sounds like a 1950s battery valve portable, in which case there won't be any transistors inside. The batteries for these haven't been made for several decades but you can build replacements from modern batteries. The radio is likely to be restorable but won't be worth a great deal, so you may be better off keeping it in a non functional state. |
7th May 2019, 1:18 pm | #3 |
Pics...
7th May 2019, 1:35 pm | #4 |
7th May 2019, 1:41 pm | #5 |
Lawrence has it. It appears to have started life as a kit which is why a google search doesn't find much info. There won't be many of them around.
7th May 2019, 2:08 pm | #6 |
I thought it looked a bit 'home-made' when I saw that green/white wiring....looks like old GPO stuff. Generally it looks like someone has made a reasonable job of construction so definitely restorable.....more so since as Paul stated, there won't be many about. Great find but don't expect 'worldwide' reception! It should give reasonable results and treat the battery valves with great care. The filaments are very delicate and can be destroyed in an instant with careless battery connection. I'd be inclined to have a careful check of the wiring and then make up some batteries...a couple of 'D' cells in parallel for the LT (1.5V) and a string of 10 PP3 9V types in series to make the 90V HT. Connect them up carefully and then switch on.....it may work to some extent and you can go from there.
I can't see any old 'waxy' caps except a low value mica type which will likely be OK. All the others look ceramic which will also likely be OK so it may only require very little work to get functional again. It's great that you have the old batteries....when the set is working you can gut them and use the boxes to make replicas fitted with the modern batteries. Should any be required, the valves are still readily available.
There are lots of brilliant keyboard players and then there is Rick Wakeman..... Last edited by Sideband; 7th May 2019 at 2:17 pm. |
7th May 2019, 2:46 pm | #7 |
Thanks Lawrence + Paul, will get some new batteries to have a play next time I have some free time.
7th May 2019, 3:00 pm | #8 |
Radio Constructor May 1957
Page 683 here: https://www.americanradiohistory.com...RC-1957-05.pdf and part 2 page 750 here: https://www.americanradiohistory.com...RC-1957-06.pdf
Never Leave Well Enough Alone... Last edited by snowman_al; 7th May 2019 at 3:02 pm. Reason: page no.s |
7th May 2019, 6:38 pm | #9 |
No excuse now....Shouldn't be too difficult to get it working.
7th May 2019, 11:42 pm | #10 |
There's a full page advert for it too- p651 in first reference.
8th May 2019, 12:45 pm | #11 |
Thanks all - I feel a bit of pressure to get the thing working now...
