Reply
Old 20th May 2024, 4:40 pm   #1
beamcurrent
beamcurrent's Avatar
Default Unidentfied Valve TV PCB
Does anyone recognise the valve IF unit in the photos? or know the date?
It is part of a dual standard tv receiver tuner unit made by Thorn in the early 1960s?
Tuners bottom left and transistor PCB sound/vision output.
ID:	297824   Click image for larger version
Regards Brian
Visit the Virtual Broadcast TV Camera Museum
beamcurrent is offline   Reply With Quote
Old 20th May 2024, 5:33 pm   #2
Heatercathodeshort
Heatercathodeshort's Avatar
Default Re: Unidentfied Valve TV PCB
The top board is a Thorn 850 series. Just a guess but I think the bottom board is some form of relay decoder. No visible CRT or timebase chassis. J.
Heatercathodeshort is offline   Reply With Quote
Old 20th May 2024, 6:50 pm   #3
simpsons
Wow!! some time since I've seen cable lacing on a consumer product if ever!!.
Whilst it may well be a Thorn designed IF chassis, the cans point to this, the metal work and sleeved connections to a control, just in view, together with the above suggests perhaps a school receiver. The turret tuner suggests non cable.
Chris
simpsons is offline   Reply With Quote
Old 20th May 2024, 7:17 pm   #4
beamcurrent
Thanks for the replies, I have googles a picture of the Thorn 850 and that is indeed the set, jolly good!
The unit that it is in is a "check" receiver installed in BBC MCR21. This is a special purpose item and is best thought of as a "tuner" in the sense that a radio tuner used in a hifi system has no speakers the Thorn WJ11 set has no tube and only a small speaker.
The handbook for it can be downloaded from the MCR21 site https://mcr21.org.uk/wp-content/uplo...1-Receiver.pdf
Regards Brian
Old 20th May 2024, 8:43 pm   #5
dazzlevision
It's not exactly an 850 IF panel, as there's no video amp, sync sep or sound output stages.
Maybe the PCB has been "cut down" as was done on a standard 950 chassis board, to put into the 16" 960 chassis....?
Name:	Thorn 850 FM IF panel - component side.jpg
dazzlevision is offline   Reply With Quote
Old 21st May 2024, 8:46 am   #6
Vintage Engr
This was quite a common practice for both Broadcast TV & also Relay companies such as Rediffusion, Top Rank, British Relay etc.
These types of unit were generally referred to as 'OAR'' - 'Off-air-receivers, and it was common to utilise a current IF /tuner combination followed by some fairly decent base-band video & audio processing. Thus the video output would be the standard 1v p-pk, and the audio a 600 ohm balanced output. Power supplies were also normally stabilised.
The extra electronics for processing was often of high quality, compared to the 'consumer' I.F/tuner etc.
Some manufacturers used fixed-frequency tuners, supplied to order, & even used a crystal oven, for better tuning stability. Many were rack-mounted construction.
As well as Thorn, there were various other manufacturers including Rediffusion, Top Rank, (a huge heavy valve-base unit), Decca, (such as the RU4011) Rank-Bush-Murphy etc.
David.
Vintage Engr is offline   Reply With Quote
Old 21st May 2024, 3:37 pm   #7
simpsons
Although the RBM A 640 black-level design is so good, anyone looking to use gated AGC on their Thorn dual standard need look no further.
Chris
Old 22nd May 2024, 10:03 am   #8
dazzlevision
Correction. The PCL86 audio output stage is present and used on the "cut down" Thorn 850 dual standard IF panel.
The PCL84 video amplifier valve holder is present but not used.
Old 23rd May 2024, 10:38 am   #9
beamcurrent
Progress has been made on this check receiver and it is now installed and working in MCR21. We found a Humax freeview box that produces a correct 4:3 output remodulated on to the RF output socket so this connects nicely to the AE input of the Thorn receiver, just a rather big "lump in the wire".
Thanks for the help in identifying the TV the IF PCB is from and yes it has been shortened and one valve is not fitted.
The hand book for the Thorn WJ11 receiver can be downloaded from https://mcr21.org.uk/technical-handbooks-slug/ scroll down to the foot of the page.
Regards Brian
Old 16th Jun 2024, 4:46 pm   #10
beamcurrent
One of our volunteers, on the MCR21 BBC Outside Broadcast Van restoration Project, has made a short video about the Thorn check receiver on YouTube https://www.youtube.com/watch?v=yp1aPpYAfu8 This is part one of two. I'll post again when part two is ready.
Regards Brian
Reply
