Old 22nd Oct 2018, 6:00 am   #1
Paul Mathew
Default Philips 794AN alignment
I have restored this set made in the US of A. The reception is great for 2 of the local AM band stations on 828kHz and 729kHz. The dial gauge reads around 670kHz when I tune in to the 828kHz station. I can't get down to the lower end of the AM band at 567kHz where one would find a third station. The schematic is based on the All American Five set, but the front end has got a far more elaborate design with two elongated cans on the left of pic, with 4 trimmer caps for the one can and 3 trimmer caps for the rear (behind the front can).
I'm reluctant to start fiddling with the trimmer caps, as I was unable to find any technical specs on this model, and in particular, alignment procedure.
This is uncharted territory for me!
Is there a safe way forward?
ID:	171319   Click image for larger version
ID:	171320   Click image for larger version
Name:	Philips Front End.jpg
ID:	171321   Click image for larger version
Name:	All American Five Schematic.jpg
Paul Mathew is offline
Old 22nd Oct 2018, 10:13 am   #2
TrevorG3VLF
TrevorG3VLF's Avatar
Default Re: Philips 794AN alignment
The circuit you show is MW only whereas the Philips 794AN is LMS. Circuit available top right and includes the rat's nest of the wiring.
If you have no band switches, things will be easier.
The alignment is a long way out so it is not just a matter of a slight adjustment of a trimmer, perhaps a bad connection or bad trimmer. The one you are after is the one across the oscillator coil.
TrevorG3VLF is offline
Old 22nd Oct 2018, 10:21 am   #3
Boater Sam
Has the phantom twiddler been at it? The oscillator is miles out, if its not been twiddles I would expect to find a faulty component or two. It cannot have just drifted so far on its own.
Boater Sam is offline
Old 22nd Oct 2018, 11:53 am   #4
Paul Mathew
Thanks for the replies. I thought a slight adjustment was wishful thinking. I will get the schematic, as this one has a 5-position waveband selector switch, and the associated rats nest of wiring!
Old 22nd Oct 2018, 5:10 pm   #5
Paul Mathew
Well, I couldn't find the schematic on the site, but I tried some ideas around the trimmer caps that I thought might be associated with the oscillator circuit, and I hit the jackpot when I soldered a 3.9nF cap in parallel with the trimmer cap in the attached pic. All the discussion around this topic seemed to be about increasing capacitance. I now have all 3 AM local stations. Not entirely on the correct spot on the dial gauge, but close enough!
Old 24th Oct 2018, 5:29 pm   #6
Paul Mathew
The (almost) final product polished and with new grill cloth.
ID:	171485   Click image for larger version
ID:	171486   Click image for larger version
