Old 20th Oct 2018, 11:44 am   #21
ms660
ms660's Avatar
Default Re: Equipment for detecting capacitor's outer foil.
Amp. plus thumb and forefinger, no dedicated test equipment needed.
Lawrence.
ms660 is offline
Old 20th Oct 2018, 2:22 pm   #22
QQVO6/40
Another easy method.
Broadcast receiver valve job (why not??).
Disconnect the antenna wire from the antenna lead and connect it to one end of your capacitor.
Crank up the volume on the radio and tune it to between stations.
Grip the capacitor on the sides of it and compare the noise from the radio with different ends of the capacitor connected to the antenna lead.
The one making the loudest noise is connected to the outer of the capacitor.
You get the idea. Same thing that Lawrence just said using a radio instead of an audio amp.
Cheers, Robert.
QQVO6/40 is offline
Old 20th Oct 2018, 2:44 pm   #23
G8HQP Dave
Might not work with a radio unless the capacitor is quite low value. Most of these checks rely on stray capacitance alone being noticeably higher in value than 'stray+capacitor value in series'.
G8HQP Dave is offline
Old 20th Oct 2018, 2:51 pm   #24
ms660
ms660's Avatar
Just to be clear with my suggestion, the capacitor is connected across the two input terminals/whatever.
I didn't explain the procedure as it should be self evident.
Lawrence.
ms660 is offline
