Old 8th Dec 2018, 8:13 pm   #1
12jslater
Default Roberts M5A mystery wires?
I have just started work on a Roberts m5a and there are three leads which should connect to a component but what? On the data sheet it doesn't show a component in its place?
Thank you
12jslater is offline
Old 8th Dec 2018, 9:04 pm   #2
ms660
ms660's Avatar
Default Re: Roberts M5A mystery wires?
Are the red (?) and yellow wires connected to anything? If so where about in the circuit.
Lawrence.
ms660 is offline
Old 8th Dec 2018, 10:19 pm   #3
12jslater
Both wires go to a tab on the chassis
Old 9th Dec 2018, 12:37 pm   #4
ms660
ms660's Avatar
What valves are fitted in your receiver?
Lawrence.
ms660 is offline
Old 9th Dec 2018, 2:31 pm   #5
12jslater
The valves are 6f6g, unknown, vr55, Ech 35, vr55
Old 9th Dec 2018, 2:37 pm   #6
ms660
ms660's Avatar
Yes, I thought they might be octals, the service data shows side contact types.
EDIT: That valve line up doesn't make sense to me.
Lawrence.
ms660 is offline
Old 9th Dec 2018, 2:44 pm   #7
12jslater
Any hope of me finding any data on this set?
Old 9th Dec 2018, 3:50 pm   #8
ms660
ms660's Avatar
This receiver gives me the feeling that it might have been got at, the mystery wires might have gone to the HT reservoir and filter electrolytics, so far as I can make out from the Trader sheet data that tag strip in your photo is a connecting point for the HT choke to the rest of the circuit, the tag the yellow is connected to I'm guessing is the feed from the rectifier, the tag that the red is connected to being the fully filtered output, one of the wires from the audio output transformer would be connected to the tag the red wire is connected to and the other wire from the audio output transformer would be connected to the anode of the audio output valve via the 100 ohm anode stopper resistor.
Lawrence.
ms660 is offline
Old 9th Dec 2018, 4:32 pm   #9
music-centre
In case you haven't seen it there was this earlier post from a member with an M5A with the later P5A valve line up
Steve.
https://www.vintage-radio.net/forum/...ad.php?t=55816
music-centre is offline
Old 9th Dec 2018, 5:25 pm   #10
AC/HL
AC/HL's Avatar
It looks like someone has cut into the wiring harness, added something, then removed it again. You'll need to trace the wires and reinstate them. There doesn't appear to be anything missing.
AC/HL is offline
Old 9th Dec 2018, 5:54 pm   #11
PJL
i suggest you post some much better pictures so we can give some advice. The pictures need to cover all of the underside wiring.
PJL is offline
Old 9th Dec 2018, 11:02 pm   #12
12jslater
Here are the wires and the tags they are connected too.
