Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay). |
28th Sep 2007, 9:12 pm | #1 |
Ferrite Pot Cores
Many moons ago Practical Television published an article concerning the replacement of the very expensive and unreliable Gate Controlled Switches that Sony used in the KV1810 television sets. The article suggested using a home made transformer to drive a conventional transistor. This transformer used a ferrite pot core, but these appear to be no longer available. Any ideas what could be used as a replacement.?
An alternative suggestion in the article was to use transformers from the decoder panel from a Rank A823, but i doubt if anyone has a pile of these (I would like to be proved wrong ). As I have two of these sets requiring GCS's, any help would be appreciated Regards ALAN |
28th Sep 2007, 9:56 pm | #2 |
Re: Ferrite Pot Cores
Alan
By pure coincidence I've been scanning LLJs articles from 1984 and the article I presume you are referring to is in the December 84 issue. The line output replacement does use the Rank A823 driver transformer but the chopper replacement uses a driver transformer from the Thorn 3500 chassis. I guess you have the article but if you don't I can send you a copy. Unfortunately I don't have any of the specified transformers but I have some old Mullard ferrite cores, which may be usable if you can determine the winding details. Keith |
28th Sep 2007, 10:24 pm | #3 |
Hi Keith
Thanks for your posting. I was working from memory(brain fade?). I'm sure that a later article (1987?) used pot cores as a substitute for the A823 transformer. In must locate the right article. Many thanks for your offer, perhaps In could contact you after I have recovered from Harpenden this sunday. Regards ALAN |
28th Sep 2007, 10:33 pm | #4 |
Hi again Alan
You are right there is a second article in February 87. If you can't locate your copy I can send a copy of the article. I'll check the ferrites I have, once I've found them in the loft and see how they compare with those specified. Keith |
29th Sep 2007, 12:03 am | #5 |
Thanks Keith
No hurry. I'm not going to be able to do the mod for a few months, but i thought I would ask in plenty of time. Regards ALAN |
29th Sep 2007, 3:30 pm | #6 |
I can remember doing this Mod on two KV1810s and neither of them worked correctly (very small picture) in fact I nearly scrapped both sets. I had to do a modification to the start up cct to give the LT rail the correct voltage, but it was so long ago that I can’t really remember what I did. But after my mod both set worked fine. If I can remember I think the ferrite transformer was a rank A823 line driver coil
