Old 20th Jun 2018, 3:44 pm   #1
Damo666
Default Connector identification
Can anybody tell me what type of UHF socket this is, please?
It's approximately 7mm in diameter x 7mm in length.
ID:	164933   Click image for larger version
Damo666 is offline
Old 20th Jun 2018, 3:47 pm   #2
peakfour
Default Re: Connector identification
BNC maybe?
Bill
peakfour is offline
Old 20th Jun 2018, 4:03 pm   #3
G6Tanuki
G6Tanuki's Avatar
Looks like a BNC to me.
(and yes in the past I fitted them to Pocketfones so I could attach a proper antenna rather than using the horrible insensitive internal metal-plate thing).
G6Tanuki is offline
Old 20th Jun 2018, 4:04 pm   #4
cmjones01
Sounds too small to be standard BNC. A mini-BNC connector of about the right size does exist, see: https://www.amphenolrf.com/connectors/mini-bnc.html, but I'm not quite convinced that this is what we're looking at.
Chris
What's going on in the workshop? http://martin-jones.com/
cmjones01 is online now
Old 20th Jun 2018, 4:05 pm   #5
TonyDuell
7mm diameter is too small for a normal BNC connector. There is a minature BNC connector which is about that size, look at RS under BNC connectors and select 'miniature' on the size filter. There's also a micro BNC which is even smaller (about 5mm diameter?)
TonyDuell is offline
Old 20th Jun 2018, 11:32 pm   #6
Damo666
Thank you for the replies, guys.
I checked a couple of the aforementioned links & the dimensions suggest this is probably a mini' BNC socket, so I've ordered one in the hope it's right.
Damo666 is offline
