Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 19th Jun 2018, 5:02 pm   #1
markchid
Default In search of Denco IFTs
Hi, I am in search of Denco IFTs (IFT14, IFT18 etc).
Clearly these are becoming extremely rare and difficult to get hold of, but if anyone has any, or know where I may be able to find them I would be happy to pay good money - within reason
Thanks!
markchid is offline
Old 20th Jun 2018, 7:33 am   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: In search of Denco IFTs
Hi Mark and welcome to the forum
As you already know these turn up even less often than the plug in coils.
If they don't have to be Denco Weyrads seem to turn up in some early transistor sets.
I have found one or two hidden away in old projects.
Loft clearances and miscalenous lots at boot sales and auctions so good luck in your quest
Mike T
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 20th Jun 2018, 11:10 am   #3
Reelman
Reelman's Avatar
Hi and welcome to the forum. Unfortunately some components, especially coils, seem very difficult to source. Often the only way to obtain them is to strip an existing piece of kit. The big problem with this is that even with the service data it is difficult to identify third party components. At least you can work out the connections.
Good luck!
Peter
Reelman is offline
Old 20th Jun 2018, 11:38 am   #4
Station X
Station X's Avatar
Do you have any pictures of drawing of these? I have a number of unused and unidentified IFTs.
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is offline
Old 20th Jun 2018, 12:50 pm   #5
markchid
You can see a few here:
https://www.worthpoint.com/worthoped...-khz-532411553
I am also looking for specs so I can build my own IFTs to closely match Dencos electrically and physically if possible.
Thanks Mike - yes I must get out to some boot sales! Will check out Weyrads. Was wondering if Toko coils can be used?
markchid is offline
Old 20th Jun 2018, 1:10 pm   #6
Station X
Station X's Avatar
Sorry, but the ones I have are shorter than that, almost cubes.
Old 20th Jun 2018, 5:19 pm   #7
Cobaltblue
Cobaltblue's Avatar
Most Toko coils I have come across are a lot smaller than the Denco IF coils
Even Toko some types can be hard to find these days
Cheers Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 20th Jun 2018, 7:26 pm   #8
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Many Denco I.F.Ts were double tuned, and are about 35mm High x 12mm Square. Detector /3rd. I.F.t's were single tuned and ca. 18mm High x 12mm square. I've just measured those on a 1.6Mhz I.F. strip I built over 40 years ago, but the 465/470kHz I.F.Ts were, IIRC, the same dimensions. The only Weyrad coils of which I know were single tuned in round cans also about 18mm High, though they may well have made others. Toko (and other brand) Japanese I.F.Ts & Oscillator coils were all about 12.5mm square. Other info. on all these is almost certainly available from the internet.
'LIVEWIRE?' is offline
Old 21st Jun 2018, 11:27 am   #9
See_Mos
The IFT's in the Bush TR82 are about the same size as the Denco ones and I think they are double tuned as well so I would like to get hold of some but it would be a shame to scrap a TR82!
Meanwhile I'm starting my Denco project with some IFT's from a Perdio kindly donated by Terry (Valvepower)
See_Mos is offline
Old 22nd Jun 2018, 1:12 pm   #10
Aub
Aub's Avatar
Hope this will be of some use.
I've attached photos of a new, unused IFT11, 465 IFT that is one of 4 I have. I will eventually built that receiver one day . They were made in 1998, when Denco briefly re-started production. They measure 38mm tall, by 17mm square. The capacitor inside is 68pf +/- 5%. I assume they are both the same value. The lower winding is covered with black tape.
All four samples I have, have the tuning slug quite a way out of the core, so I assume they've never been adjusted.
The last four papers are what I received after making an initial enquiry back in 1996.
Interestingly, I always thought that these were IFT11/455 , not 465, so i've only just discovered that!
Aub
ID:	165036   Click image for larger version
ID:	165037   Click image for larger version
ID:	165038   Click image for larger version
ID:	165039   Click image for larger version
Ignorance of The Law is No Excuse - but I didnt know that!
Aub is offline
Old 22nd Jun 2018, 1:14 pm   #11
Aub
Aub's Avatar
The last two papers.
ID:	165051   Click image for larger version
Aub is offline
Old 22nd Jun 2018, 1:58 pm   #12
G8HQP Dave
So we have learned that the 465kHz IFT has a Q of 70 and C=68pF (I have a feeling that the original design used 65pF?). That goes a long way to enabling replication. They were probably slightly undercoupled - with the cores in the outermost tuned position?
1.6MHz Q is 100, and 10.7MHz Q is 90.
I too have some Denco IFTs, mainly 1.6MHz. I too will one day make that receiver!
G8HQP Dave is online now
Old 25th Jun 2018, 1:23 pm   #13
markchid
Thanks all!
Some great information - and photos too. Bit jealous - I must get out to those car boot sales - you never know.
I would 3D print the formers and build some kind of winder (assuming these are not easy to find!)
Mark
markchid is offline
Old 25th Jun 2018, 6:01 pm   #14
Valvepower
Valvepower's Avatar
Whilst doing the mammoth pre-move de-clutter I found a Perdio PR73 transistor radio. The cabinet was very, very rough plus it gave up its ferrite rod aerial for a Hacker Mini Herald to survive - just need the strap handle for the Herald - but that's another want post for another time!
Anyway, it has some IFT's that maybe of use - they are single tuned but may help get a project underway.
This is FOC.
Pictures attached.
Regards
Terry
ID:	165218   Click image for larger version
Valvepower is offline
Old 26th Jun 2018, 9:05 am   #15
See_Mos
Hi Terry, I would be interested in that one as well, if Mark doesn't want it.
See_Mos is offline
Old 26th Jun 2018, 1:32 pm   #16
Valvepower
Valvepower's Avatar
Hi Trevor,
If Mark doesn't want it it's yours.
Regards
Terry
Old 27th Jun 2018, 5:33 pm   #17
Valvepower
Valvepower's Avatar
Hi Trevor,
Consider the Perdio PR73 PCB yours.
I'll PM you.
Regards
Terry
