11th May 2016, 11:14 am | #1 |
Intel 87C196KDH - Can anyone read it?
I have a processor which I need to read the code from, I'm looking in particular for text strings rather than code disassembly or anything like that.
I have no idea if the code is write protected but it's worth a shot either way. Dave. |
11th May 2016, 10:16 pm | #2 |
Re: Intel 87C196KDH - Can anyone read it?
Hi Dave
Not sure if you already have it but I found the datasheet for this device - attached. What package is your chip in (prefix letter to the main part number)? Your chip is the 87 version which has 32KB OTPROM. I also notice that the datasheet mentions a OTPROM security key which suggests there might be protection. Anyway to my knowledge there are two ways to attempt dumping the internal ROM. The first is to try using the programming interface but this probably won't work though as often the processor only contains logic that will write to the memory). The second is to write code to dump the internal ROM using the processor itself. I have done this successfully on the Intel 8049 by getting the processor to boot from external memory and then redirecting ROM accesses from external to internal ROM. This might be possible on your chip but it is not a 5 minute job. Of course the processor has to be fully functional. Cheers Robin |
12th May 2016, 11:07 pm | #3 |
Hi Robin,
I had a tentative look at the datasheet but I was mainly looking for details of the programming interface. The processor is fully functional, I have access to the unit it's from too. The package is a 68 pin PLCC type, unfortunately I don't have a spare holder and although I can do limited modifications to the original unit I probably can't modify it too much. I've mused the idea of trying to get it to run a bootloader and redirect to external ROM to spit the internal memory out through RS232 or one of the 8-bit ports, however I know nothing about the architecture of this device so I suspect I may already be fighting a losing battle. I'm familiar with PIC and Atmel stuff but not these mysteryboxes. Dave. |
