Old 2nd Mar 2021, 8:25 pm   #1
billy.bates
Default Help required please, Marconi TF 1370A
Hi, I have been repairing a Marconi TF 1370A wide band signal generator & I'm trying to get it to its original spec on the 400Hz & 1KHz frequencies which should be within 0.5%. Currently I'm at 0.6 & 0.8%, I have gone through replacing out of tolerance carbon comp' resistors, the HT & LT supplies are spot on & most of the caps have been replaced or are good. Any ideas/help would be most welcome! God bless, Bill.
billy.bates is offline
Old 3rd Mar 2021, 6:13 pm   #2
WME_bill
Default Re: Help required please, Marconi TF 1370A
Marconi TF1370. AF Oscillator.
Wein bridge oscillator, with variable capacitor for tuning and switched resistors for each range. There are trimmer resistors and also a little trimmer capacitor for the top end of each range. Surely you just need to tweek those. Ranges B and C. Lovely smooth tuning with the variable capacitor.
When tweaking, you will have to be prepared to put the screening covers back on for the higher frequency ranges.
The frequency accuracy quoted in the manual and 1972 catalogue is 2%, so I think you have done well to improve it so much.
wme_bill
WME_bill is offline
Old 12th Mar 2021, 1:52 pm   #3
billy.bates
Thanks for your response, I'll investigate & see where I get to. Thanks!
God bless, Bill.
