Old 28th Feb 2021, 10:39 pm   #21
dglcomp
Default Re: Rear exit 13A plugs
Just remembered that there was a duraplug weatherproof cable coupler based around 13A sockets and it seems MK also sold it. Found a set on the bay, though looking around you might just be available to find the plug on it's own,
https://www.ebay.co.uk/itm/CCP133-BL...D/233760510247
I got given one many moons ago and it would happily take normal flex diameters and the plug fits in regular sockets just fine.
dglcomp is offline
Old 1st Mar 2021, 4:50 pm   #22
Lancs Lad
Lancs Lad's Avatar
Just out of interest, merlinmaxwell, what brand of sockets do you have?
Some cheaper DIY store own-brands are made from pretty thin, flimsy materials, as I'm sure you know.
I'd choose MK or Crabtree if I were you, or even Volex, they're not too bad. They're much sturdier, although the quality of MK accessories is a bit hit-and-miss these days
Best Regards,
Peter.
Lancs Lad is offline
Old 1st Mar 2021, 5:57 pm   #23
They are MK now (originally Legrand, we were poor!) and I am glad I secured the back boxes well! To be honest it has only happened four times in the past few years. I have terminated the vacuum cleaner lead in an IEC "kettle" plug and that is connected to a generic moulded IEC lead. I tried it, the IEC lead lines up when the vacuum lead is pulled and comes apart in a controlled manner, probably not designed for a hot disconnect too many times, much better than breaking a socket.
Old 2nd Mar 2021, 11:00 am   #24
Brigham
I seem to remember BS1363 specifying a bottom-entry plug.
Although it could be just another false memory...
Brigham is offline
Old 2nd Mar 2021, 2:09 pm   #25
emeritus
Side entry was specified in Home Office requirements more than 100 years ago, although these were only advisory. These requirements are referred to in the GEC catalogue of 1911 without actually providing a reference number to any statutory specificaton. A note on one of the pages of GEC's "Home Office Pattern" plugs says:
" The plugs here illustrated are all provided with a registered form of hand shield and handle, whereby the flexible cord in no case passes through the hand of the user, thus rendering personal injury impossible even if the Plug is inserted on a dead short, neither is it possible to withdraw the Plug by pulling the flexible cord. The plug is withdrawn by using the handle protected by the shield.
Our efforts in designing this series of Wall Plugs have been greatly aided by the particularly clear and concise manner in which the objectionable features of the present types and the desirable modifications are set forth in the Annual Report of the Electrical Inspector of Factories, G. Scott Ram, Esq. (see Annual Report of the Chief Inspector of Factories and Workshops for the year 1909, pages 183 and 184). " {emphasis in the original.}
I did try to find a copy of this report a few years ago. If it does still exist, it seems it would be in the Public Records archive at Kew, and would involve a personal visit to look through the paper document collection. One for my bucket list!
GEC did also offer a somewhat wider range of top entry plugs at lower prices, in which the cord did pass through the hand of the user.
emeritus is offline
Old 2nd Mar 2021, 2:28 pm   #26
Nicola_Jayne
Seen a very elegant solution to this issue using CEE7/7 Schuko plugs on a powered profiling hospital bed.
The bed regardless of its intended (230V) market comes with a Schuko /CEE 7/7 plug which is 'rear exit', as is the norm for those, when sold into the UK/ ROI market it comes with a short (300 mm) patch lead BS1363 to CEE7/7 inline socket.
So much as the suggestions of the lawnmower or kettle plugs inline, if you don't unplug before pulling the bed away from the bed head unit it pings the Schuko apart.
Nicola_Jayne is offline
Old 2nd Mar 2021, 2:34 pm   #27
Beobloke
Sounds like a Furutech FI-1363 will be perfect for this.
However, make sure you’re sitting down before you read the price as it belongs firmly in the ‘Audiophoolery’ thread!
https://www.futureshop.co.uk/furutec...SABEgItwvD_BwE
Beobloke is offline
Old 2nd Mar 2021, 5:52 pm   #28
IEC thing done, she comes on Friday, I wonder...
I tested it at various angles and as expected, works a treat. The last incident was hoovering the cable, sense prevailed and it wasn't used after the cores became visible. 50m drum of twin flex got from Toolstation, enough for a few repairs. I like Toolstation, a sort of polite Screwfix, here we have both down the same dead end road, worth the extra hundred yards or so (even on foot). A good Sunday walk to get stuff too (five mile circular route, seven if I include two nature reserves).
Old 2nd Mar 2021, 11:24 pm   #29
Lancs Lad
Lancs Lad's Avatar
This 'lady who does' of yours sounds like a real character!
I'm amazed you let her come into the house, knowing what havoc she is likely to wreak.
Imagine running over the vacuum cable enough to chop up the outer covering, and expose the inner cores. Surely that takes some doing!
What model of vacuum do you have? My current one is the Vax Air, Lift Off, Steerable Pet model. I bought it in September 2019, after the electrician who rewired my house knackered my previous one hoovering up lumps of plaster - but that's a whole other story...
My elderly Great Auntie used to have a cleaning lady who, when she was vacuuming the stairs (with a 1950s Hoover Senior that weighed a ton) always sang Red Sails In The Sunset, at the top of her (very good) voice. It was priceless! I think she liked the acoustics of the stairwell...
There's something very sweet and comforting about cleaning ladies, if you know what I mean? Sort of quintessentially English, and nostalgic...
I hope you don't let her dust any fragile, breakable valuables!
Best Regards,
Peter.
Old 3rd Mar 2021, 12:10 am   #30
matthewhouse
matthewhouse's Avatar
You could treat her to a nice new cordless vacuum cleaner, some of them work impressively well!
matthewhouse is offline
Old 3rd Mar 2021, 12:16 am   #31
Tractorfan
Tractorfan's Avatar
Smile Re: Rear exit 13A plugs
The nearest thing I have is this BS 1363 13 amp 'Duraplug' in-line connector.
I don't know if they're still available. A bit fiddly to fit, but fused with a cable grip. It fits any standard socket and does not foul the switch dolly.
I also had a BS546 5 amp version and, I'm not certain, there might even have been a BS546 15 amp one as well.
Name:	13A rubber connector (1).jpg
ID:	228129   Click image for larger version
Name:	13A rubber connector.jpg
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline
Old 3rd Mar 2021, 12:41 am   #32
matthewhouse
They are still current MK Duraplug products:
CCP53BLK - 5A round pin plug and trailing socket
CCP153BLK - 15A round pin plug and trailing socket
CCP133PBLK - 13A square pin plug, a trailing socket doesn't seem to be listed in the current catalogue.
