26th Feb 2021, 2:28 pm | #1 |
Bush 82CL squealing
My old Bush 82CL has started squealing on reception of strong signals, It clears up if i rotate the radio. I'm thinking the AGC Capacitor.
Here is a clip of the radio in action. https://www.youtube.com/watch?v=nRfx...ature=youtu.be
Help!! I've been electrocuted by a glass thing that glows |
27th Feb 2021, 12:37 am | #2 |
Re: Bush 82CL squealing
P.S... I'm pretty sure its not QRM it's picking up as my other radio's aren't receiving it
27th Feb 2021, 2:17 am | #3 |
If you haven't done so already, replace all the electrolytic capacitors.
Don't forget there are a couple on the back of the chassis. while you have the chassis out, take the opportunity to treat the wave change switch with some switch-cleaner.
-- Graham. G3ZVT |
27th Feb 2021, 2:42 am | #4 | |
Band switch has been cleaned. Cheers Jay.
27th Feb 2021, 9:13 am | #5 |
I'm a little careful about where I buy electrolytics from. There are some dodgy components floating around, so I choose reputable brands and get them from an accredited distributor, usually Farnell or Mouser.
Pulling something apart is a fair amount of effort and I don't want to have to do it all again just because I saved a quid spread over all the capacitors. I thake the do-it-once low risk option. Howling means feedback. So decoupling capacitors are likely suspects, and here you do not need to be picky about the right values, you can usually go up in value a fair bit and see no problems. David PS, I'm a Yorkshireman and Yorkshire is effectively twinned with Aberdeen Remember the ancient joke that copper wire was invented when someone dropped a penny midway between a Yorkshireman and an Aberdonian? In both Yorkshire and Aberdeen, we like to describe ourselves as 'Careful'.
27th Feb 2021, 10:18 am | #6 |
Langrex will do 10x 100uf 25v you only need four for £1.65 free delivery
https://www.ebay.co.uk/itm/25V-100uF...AAAOSwDg5depKi and these 10uf 25v X 10 you only need three and are avaliable for only £1.19 free delivery. so for £2.84 you will have enough to repair two Bush 82CL. https://www.ebay.co.uk/itm/10-x-10uF...MAAOSwb69Zu6CD Have purchased from both these vendors in the past all good components. or you could recover some of these values from an old tv chassis or satellite receiver. John |
27th Feb 2021, 3:04 pm | #7 |
Thanks for the advice & links regarding capacitors, My post regarding capacitor prices was more in line with doing bulk recaps. Replacing waxies ect. Not one off radios, Well i have the bush stripped down, Am i right in thinking C10,C22,C23,C25,C27 Are the electrolytics ?
'Can't see any polarity markings and i'm working from a schematic for an earlier version. The one that uses OC Transistors. Mine uses AF-117, Seems to be slight differences in the layouts. I did notice a broken hunt cap, The one that couples the signal from the base of TR1 to the band selector RadioWrangler. You heard about the scotsman who dropped a pound coin ? When he bent down to pick it up it hit him on the back of the head
Help!! I've been electrocuted by a glass thing that glows Last edited by Radio Scotland; 27th Feb 2021 at 3:05 pm. Reason: more info |
27th Feb 2021, 3:25 pm | #8 |
27th Feb 2021, 3:30 pm | #9 | |
I need to source the correct schematic
27th Feb 2021, 3:32 pm | #10 |
27th Feb 2021, 4:09 pm | #11 | |
27th Feb 2021, 5:45 pm | #12 |
The broken cap is marked .01 i take it thats .01 uf as in 10.000 pf ?
27th Feb 2021, 7:39 pm | #13 |
Am i right in thinking the 7 electrolytics are 4 x 100 uf & 3 x 8 uf ?
27th Feb 2021, 8:01 pm | #14 |
27th Feb 2021, 8:05 pm | #15 |
Cheers lawrence i'll order some up, 8 uf isn't a preferred value these days so i'll go for 10 uf, Should i replace the small black hunt caps ?
27th Feb 2021, 8:29 pm | #16 |
If they are leaking I would replace them if it were mine, that's because I don't like leaking capacitors full stop......But I think opinions might differ depending on the circuit function and the fact that they are not subject to high voltages in a transistor receiver.
Lawrence. |
27th Feb 2021, 8:34 pm | #17 |
I'll replace the broken one and leave the others if performance is ok,
Jay.
27th Feb 2021, 9:02 pm | #18 |
Black Hunts are not the best news these days.
27th Feb 2021, 10:10 pm | #19 |
Hi Radio Scotland.
In reference to your question in post #12 yes 0.01uF is 10,000pF and it can also be described, or marked as 10nF nF is just another way of describing thousands of pF. Paul |
27th Feb 2021, 10:40 pm | #20 | |
Thanks for the info regarding the .01 caps paul As for the hunts would it be ok to replace them with ceramic caps ? Jay.
