Old 26th Oct 2021, 1:48 pm   #1
Radiocruncher
Radiocruncher's Avatar
Default Nordmende Galaxy Mesa 7000 slider knob removal
Hi
I’ve got a lovely Nordmende Galaxy Mesa 7000 here that I’ve done a fair bit of work on. However it has issues with corrosion of the through holes on the main board. I’ve tried reflowing it in situ but it’s very difficult to acces to remove the old solder. I need to get the board out of the radio. The only way I can see to do this is to remove the knobs on the 3 sliders. The trouble is, despite using a fair bit of force, that they just won’t budge. I can’t lever them against the front as it’s perspex. If I use much more force then I’m sure they will snap off which would be disastrous. Does anyone know how they are fixed on and have any tips for removal. Here’s a link to one of the videos I made some time ago.
https://youtu.be/-Yuq7XxMKQ4
Thanks in advance
Graham
Radiocruncher is offline
Old 26th Oct 2021, 4:23 pm   #2
Squipper
Squipper's Avatar
Default Re: Nordmende Galaxy Mesa 7000 slider knob removal
Hi Graham.
The Mesa knobs for the sliders are probably glued in. See images.
ID:	244293   Click image for larger version
The waves I have discovered will not have any practical application - Hertz
PAUL - BVWS Member
Squipper is offline
Old 26th Oct 2021, 4:42 pm   #3
Radiocruncher
Thanks Paul
I think they will break if I use any more force on them. I could try some isopropyl to see if it would loosen it or maybe some acetone but I don’t think I can get behind them.
Regards
Graham
Old 26th Oct 2021, 8:32 pm   #4
MotorBikeLes
Those slider knobs are identical to those used on many of the F4 series colour TVs (eg, 26" Ambassador). None of those are glued on. I have two of the old sixpence Woolworth screwdrivers which I heated to red and bent the ends through 270 degrees. One either side of the knob and they should pull straight off no problem. I had a Galaxy mesa 2200 years ago, I probably removed slider knobs on that without problems. The only time they are glued on is when somebody has knocked them off (sideways?) and lost half the end. Then you need araldite, and it is permanent. OK, today I would probably use a hot glue gun.
Les.
P.S. Do NOT use acetone, the knobs will probably disintegrate.
MotorBikeLes is offline
Old 26th Oct 2021, 10:17 pm   #5
Radiocruncher
Thanks for all the info Les. I’ve really given them a lot of stick to try to get them off so someone may have glued them in the past. Good tip on the bent screwdrivers so I may give that a go. I hear what you are saying about the acetone. It was a last resort type of comment and probably won’t happen.
