10th Feb 2018, 7:57 pm | #1 |
Leak Stereo 30 plus won't turn on
Hi - i'd appreciate any pointers anyone may have. I've a Leak Stereo 30 Plus which I used up until a few years ago. I don't remember it ever stopping working, but I tried the other day and it was as dead as a doorknob! I've checked the AC and DC fuses, as well as the plug fuse all of which are fine. I contacted a couple of specialists who were more interested in refurbishing the amp at enormous cost whereas I'd just like to repair it/get it working - I'm hoping it's something simple as the amp was hardly used and otherwise in good condition.
Thanks in advance |
10th Feb 2018, 8:32 pm | #2 |
Re: Leak Stereo 30 plus won't turn on
A couple of questions:-
1. Does the light on the front panel come on? 2. Do you have a multimeter that you can use?
Martin BVWS member GQRP Club |
10th Feb 2018, 8:33 pm | #3 |
I don't know this amp, but I have a Leak Delta 30 of (I presume) a similar age. Mine just has a simple on/off switch combined with the volume control. Maybe a quick squirt of Servisol (or similar) switch cleaner might work. Cheers, Pete.
11th Feb 2018, 12:49 am | #4 |
:If the switch has failed, you may find switch cleaner doesn't cure it, it will need replacing. Trouble is they're not available, you'd have to have it specially made.
You didn't contact me though! |
