11th Dec 2017, 3:00 pm | #21 | |
Re: Cutting and soldering Teflon covered wire
Second (again of the risk of going OT), way back, we used to fit a Hellerman sleeve on the end. Better suction and if it burnt- simply cut off the burnt bit. |
11th Dec 2017, 3:36 pm | #22 | |
They work well, but need ventilation with PTFE. Keep the tip blades free from any fragments! |
11th Dec 2017, 6:52 pm | #23 |
That light green multi-core i used on my latest meter repair is PTFE covered. Ideal for that particular application- ie multi stranded for fracture resistance but when you kink it into place it stays kinked. I too use a stanley knife blade, rolling the wire across a piece of wood and pressing lightly. Fingernails into the nick in the insulation and it comes off easily. Looking at the colour it may well be silver plated not tinned.
11th Dec 2017, 7:11 pm | #24 |
It is silver plated because of the extrusion temperature of PTFE, lovely stuff to work with, and a right pain to lace up, the lacing has a tendency to wander about.
11th Dec 2017, 10:50 pm | #26 |
I've always made a lengthwise cut and then peeled the end like a banana, snipping the 'peel' away after. Some of the panels we've had from ex-mod equipment have been made with pink ptfe wire.
Kevin |
12th Dec 2017, 11:58 am | #27 |
Pink was the colour specified for wire in MOD contracts in the 1970's. Cables were identified by numbered and lettered slip-on sleeves of various colours at both ends.
12th Dec 2017, 2:56 pm | #28 | |
As to stripping PTFE-insulated wire, I remember the guys from GEC had a special tool (whose name I forget - something like Stall?) that was a version of the "Knipex" single action cut-and-pull type but had a gripper which rotated through an (adjustable up to about 90 degrees) amount as it pulled the cut piece of insulation off, so it essentially 'unscrewed' the insulation off the wire. |
