1st Mar 2013, 1:56 am | #1 |
Roband Power Supply
Is anyone able to provide a schematic or manual for a Roband V50/50 adjustable regulated power supply please? It is 0-500Vdc, 500mA, made at a guess in the early 1960's. Uses a multi-tap, multi winding transformer, semiconductor diode bridge and a valve series pass regulator. Information on anything similar (V50/25, V25/x, etc) would likely assist. Thanks.
1st Mar 2013, 1:30 pm | #2 |
Re: Roband Power Supply
Wow, some power supply! Unfortunately can't help, is this the one that was on the trade Me website?
As a silly question, do the valves act as series pass elements over the whole 0-500V, or are transformer windings switched in and out so it only regulates over, say, 50V? The reason for asking is I have a 0-350V PSU that is stepped in 50V. Not yet tried it, needs checking out first, just in case! Boi |
4th Mar 2013, 6:58 am | #3 |
Yes it's quite clever. There are three settings switches. Hundreds of volts, tens and units. One sets the required output on these switches. Not only is the transformer tapped, but the reference voltage to the regulator amp is switched by the settings switches so the "dialled-in" setting results. Now I've got it repaired it seems to be pretty much accurate to a volt or so over the whole 499V range. The regulator itself is very stiff (although slow) and once settled shifts only negligibly from about 10% load to full load.
21st Dec 2013, 5:18 pm | #4 |
I have just acquired one of these and would appreciate any info available.
Regards, Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. |
