Old 27th Oct 2019, 3:42 pm   #1
Jonnie_L_Plate
Default Wolf Cub Drill Restoration Question
Hello
I was just wondering if anyone could help me identify a small electrical part from my Wolf Cub Drill? I am pretty much a novice but I suppose we have to start somewhere. The bit was just detached from one of the brush wires.
Thanks
ID:	192495   Click image for larger version
Jonnie_L_Plate is offline
Old 27th Oct 2019, 5:09 pm   #2
Default Re: Wolf Cub Drill Restoration Question
That's a suppression choke, designed to control the interference caused by sparking between the brushes and the commutator as it rotates. In times-past, this interference - if unsuppressed - could wipe out TV/radio reception over a wide area.
Yours looks like it's come to the end of its useful life - I'd suggest maybe something like this:
https://uk.rs-online.com/web/p/leade...ctors/8807161/
as a replacement?
Old 27th Oct 2019, 10:01 pm   #3
Ed_Dinning
Hi John, it should work witout it but may give radio and TV interference.
Spare brushes are still available, if you get over this way I may be able to find you something suitable.
These drills, if serviced occasionally will go on forever.
I also have its bigger brother, a real "gut buster" that has done a very serious amount of work over the yeas and is still going strong.
Ed
Ed_Dinning is online now
Old 28th Oct 2019, 12:56 am   #4
Jonnie_L_Plate
Many thanks for your replies. I have ordered some of these chokes.
As we speak I am putting it back together so when it's done I'll post a pic and results.
Got 2 B&D drills to look at after this, both absolutely filthy, quite enjoying this new hobby.
Thanks guys, keep you updated.
Old 28th Oct 2019, 11:09 am   #5
mark_in_manc
You might find you want to build a speed-controller next, which greatly increases the range of things these can do in metal (otherwise they go a bit, or a lot, too fast). Then the folks on here will really get their electronic teeth into you
mark_in_manc is offline
Old 28th Oct 2019, 7:20 pm   #6
Techman
Techman's Avatar
If you like old drills then I suggest you have a good look through all the pages of this thread - you might be surprised, then add your drills, with pictures, to that thread:-
https://www.vintage-radio.net/forum/...d.php?t=148750
Techman is offline
Old 30th Oct 2019, 8:56 am   #7
jamesinnewcastl
jamesinnewcastl's Avatar
That brings back memories - my dad had one in his tool cupboard - didn't work and it weighed a ton! Hmm, or was I just small and weedy?
I have a big SDS drill now and walls simply tremble at its approach!
James
jamesinnewcastl is offline
Old 30th Oct 2019, 5:29 pm   #8
rambo1152
rambo1152's Avatar
Personally I would not want to use a metal-clad power tool like that.
At the very least, fit an RCD plug .
Graham.
G3ZVT
rambo1152 is offline
Old 30th Oct 2019, 8:27 pm   #9
Heatercathodeshort
Heatercathodeshort's Avatar
Agree. Many of these old tools required an earth and were lethal when used outdoors or on damp surfaces. The earth wire could be cut, pulled from the plug or come into contact with the live wire due to cuts etc. It was the same problem with early electric lawn mowers. They are all double insulated these days or run from a 110v isolation transformers for safe use for outdoor applications such as building contractors.
Enjoy your old tools but only use them through an RCD.
Heatercathodeshort is offline
Old 31st Oct 2019, 2:24 pm   #10
Argus25
No Longer a Member
Wow, I haven't seen a Wolf Cub drill like that for over 45 years. Well worth restoring, very cool drill. I remember trying one out after I graduated from a push/telescopic style hand drill and thought all my Christmases had come at once.
The modern world of plastic double insulated drill enthusiasts would probably frown on that lovely metal body. I think its great, just make sure its properly earthed.
Argus25 is offline
Old 31st Oct 2019, 4:15 pm   #11
Techman
Techman's Avatar
If I'm worried I always run them via an isolation transformer.
Have you seen that other drill thread I linked to, Argus?
Techman is offline
