Old 16th Apr 2019, 8:30 am   #21
Don_Zalmrol
Don_Zalmrol's Avatar
Default Re: Tektronix 2211 scope short-circuited
May I swap the 0.15uF MKT 250V with a 0.15 MKP 630V?
It's a bit tricky to get the 250V version locally.
Don_Zalmrol is offline
Old 16th Apr 2019, 8:33 am   #22
MrBungle
MrBungle's Avatar
Has to be a an X2 one which will have a low voltage intentionally so unfortunately no.
MrBungle is offline
Old 16th Apr 2019, 8:35 am   #23
Don_Zalmrol
Ah pitty and a little higher capacitance (220nF)? It's an X2 rated for 275V.
https://www.gotron.be/ontstoorconden...22-5mm-x2.html
Old 16th Apr 2019, 8:39 am   #24
MrBungle
MrBungle's Avatar
That would do the job. Check the pitch of the pins is correct as well. Looks about right.
MrBungle is offline
Old 16th Apr 2019, 10:40 am   #25
Don_Zalmrol
Pins do not match
Need 22.5mm.
https://www.benl.ebay.be/itm/5x-R46K...gAAOSwnWpcNh2j
Should I replace it though?
Old 16th Apr 2019, 10:44 am   #26
MrBungle
MrBungle's Avatar
Ah.
Yes anything RIFA shaped needs replacing.
Some motivation. This is what one did to my Philips scope:
MrBungle is offline
Old 16th Apr 2019, 10:47 am   #27
Don_Zalmrol
Duly noted!
Old 28th Apr 2019, 6:18 pm   #28
Don_Zalmrol
It's alive again after changing the old caps on the PSU side.
Thanks for the help!
Old 28th Apr 2019, 7:42 pm   #29
MrBungle
MrBungle's Avatar
Excellent news. Thanks for posting back
MrBungle is offline
