25th Apr 2019, 9:50 pm | #1 |
Another UNILAB Educational Osciloscope
I turned on my Unilab 032.602 scope for the first time in about ten years and got.... no trace.
Helpfully I found this old thread where G4 Pete posted a schematic and noted that he fixed two with the same fault -a bad transistor holding the grid at -50V. https://vintage-radio.net/forum/showthread.php?p=839054 (Maybe the mods want to add this post to that old thread? Seems relevant.) Upon looking inside I went straight to the grid and, lo and behold, it was stuck at -50V. Aha it's bound to be the same fault as Pete's two! So I replaced the same transistor Pete did with an MPSA42 that I had and... still no trace! You know what it was, don't you? One of the SKE1/06 rectifiers was dead, so I had no -9V rail. I probably should have measured the rails first I suppose! Anyway I replaced all of them with some 1N4007s (overkill I know) and it works now. However, on one particular timebase setting I get ripple on the trace (unaffected by Y gain), does anyone else get the same thing? |
25th Apr 2019, 10:32 pm | #2 |
Re: Another UNILAB Educational Osciloscope
Do you still get the ripple with the case back in place and the input leads disconnected?
Alan |
26th Apr 2019, 8:53 am | #3 |
Yes. In fact I think it's there all the time, you just can't discern it at high or low scan rates. It looks like rectifier ripple so I guess it is simply the imperfect HT being derived from a simplistic voltage doubler.
26th Apr 2019, 12:46 pm | #4 |
Seems to be internally generated in any event. Might be worth checking out the ageing electrolytics in the power supply I guess.
Alan |
26th Apr 2019, 6:35 pm | #5 |
Hmm there seems to be 2Vpp of ripple on the HT. Not much
