Reply
Old 14th Nov 2025, 7:06 pm   #1
g0hze snowy
g0hze snowy's Avatar
Default pioneer sx-20a
Hi Peeps, once again i am in need of your advice.
Whilst i can replace visually faulty components and am learning, albeit slowly, to test components that look ok but are in fact faulty.
What i am finding difficult is understanding what each part of a circuit does, at the moment i have 2 x pioneer sx-20a both exhibiting the same fault, stuck in protection mode, 1 of them i have had advice from this site re 0.27ohm resistor replacement, also the power amp transistor and its driver were faulty so they have been changed, i have tried the factory reset procedure but no joy.
So onto the question, at last you say ha ha, how can i temp bypass the protection circuit to see if the items are worth spending more time and money on them, they do represent a medium amount of loot in the purchase and the cost of spares already fitted.
so once again your advice and guidance is sought.
TIA
Snowy
g0hze snowy is offline   Reply With Quote
Old 14th Nov 2025, 7:11 pm   #2
g0hze snowy
Default Re: pioneer sx-20a
Mediators, please move to correct post block, sorry
Old 15th Nov 2025, 8:51 am   #3
Diabolical Artificer
Diabolical Artificer's Avatar
There's a bloke called John audio tech on Youtube who did a series of video's a while back on transistor audio amplifiers EG the differential pair, the VBE multiplier etc, that might help you understand the building blocks of an amp more.
Re protection circuits I have a Pioneer amp on the bench at the moment in protection. The protection circuit is pretty simple as are most protection circuits in amps. They do 3 things 1) delay the connection of the power amp to the speakers via a relay at switch on 2) If DC is present at the OP of the power amp, the relay opens & 3) disconnect the power amp from the speakers at sw off.
The protection circuit does 1 & 3 with a simple RC time constant circuit which then turns on or off a transistor & thus the relay. Therefore check to see if that part is ok & check for DC on the OP of the power amp. That leaves the relay itself which can be checked with a meter & bench power supply.
Andy.
Diabolical Artificer is online now   Reply With Quote
Old 15th Nov 2025, 12:59 pm   #4
g0hze snowy
Thanks Andy, will check those suggestions tomorrow when i can get to my workshop.
Reply
