Reply
Old 10th Nov 2025, 8:53 pm   #1
Oldslap
Default Pye 1005
Hi, I've recently picked up a Pye 1005 minus a stylus. It also came with small bag of bits - the red knob & spring + a small plate - see attached. It's a similar size to the end of the tone arm. I've fitted a stylus & the red knob & spring. It plays really well, but the cartridge just seems really loose in the arm, is this correct? I'm wondering if the small plate is part of the arm/cartridge assembly, can anyone advise? The arm won't return when it gets to the end of the record which I'm presuming is an adjustment.
File Type: pdf com.google.android.apps.photos.Image (1).pdf (849.1 KB, 39 views)
File Type: pdf com.google.android.apps.photos.Image.pdf (1.79 MB, 24 views)
Oldslap is offline   Reply With Quote
Old 10th Nov 2025, 10:09 pm   #2
Edward Huggins
Default Re: Pye 1005
Even when set up properly the cartridge may feel loose in the tone arm. Check the tracking weight, it should be 2 grams. The faulty arm return should be quite easy to fix. You need the Service Sheet for a BSR UA15 available from the Service Data link above. It is listed as BSR UA16, but is essentially the same.
Edward.
Edward Huggins is online now   Reply With Quote
Old 11th Nov 2025, 2:24 pm   #3
Oldslap
Thanks for the information - I've downloaded the UA-16 service sheet.
Old 11th Nov 2025, 7:25 pm   #4
Michael Maurice
Michael Maurice's Avatar
I have found when servicing these players that all the capacitors on the two circuit boards are duff and in need of replacement.
If you don't know what youre doing, leave well alone.
Forum Moderator
www.michaelmauricerepairs.co.uk
Michael Maurice is offline   Reply With Quote
Old 12th Nov 2025, 2:47 pm   #5
Techman
Techman's Avatar
There is no adjustment. It's a clever bit of mechanics known as the trip pawl that detects the speeded up travel of the arm as it travels the play out groove at the end of the record and works on very light friction. The deck needs a full service to remove old gummed up lubrication and there's information on how this all works in one of the instructional threads at the top of this page, so have a good read.
Techman is offline   Reply With Quote
Reply
