Reply
Old 10th Nov 2025, 1:35 pm   #1
Tinter 64
Default HMV Stereomaster 2328 spares
Hi everyone,
I have just purchased a HMV Stereomaster 2328 but missing so knobs.
Would anyone know where I could get spares?
Also, doesn’t appear to have aerial for radio.
Thanks in advance
Tinter 64 is offline   Reply With Quote
Old 10th Nov 2025, 3:09 pm   #2
dazzlevision
Default Re: HMV Stereomaster 2328 spares
This item dates from the mid-1960s and the original manufacturer is no longer in existence.
I suggest you post a wanted ad in the relevant section of this forum.
This thread may help identify the knobs: https://www.vintage-radio.net/forum/showthread.php?t=187651
Here's a photo from the HMV brochure for the 2026, which is the same as the 2328, but without VHF/FM radio. The photo of the 2026 shows the knobs better than that of the 2328.
The 2328 will probably have a built-in VHF/FM radio aerial, which is plugged into the radio aerial socket the the rear of the unit. If it does have this, it can be unplugged to connect an external VHF radio aerial if required. Note that the radio part of the 2328 uses two AF116 Germanium transistors, which suffer from "tin whiskers syndrome" and that may be stopping the radio part from working at all.
Name:	HMV 2328 Streomaster contol knobs photo.jpg
dazzlevision is offline   Reply With Quote
Old 10th Nov 2025, 3:32 pm   #3
Tinter 64
Thanks buddy, appreciate your help
Old 14th Nov 2025, 5:32 pm   #4
jimbilton
I have a HMV Stereomaster 2328. Here are some photos of one of the knobs. I don't have any spare ones, unfortunately, but somebody on the forum could well have.
The diameter is 30mm
Projection of the boss from the underside is 12mm.
ID:	321521   Click image for larger version
ID:	321522   Click image for larger version
jimbilton is offline   Reply With Quote
Old 14th Nov 2025, 8:02 pm   #5
Uncle Bulgaria
Uncle Bulgaria's Avatar
If no luck with a 'wanted' ad, I could probably cast the knobs in resin from an original. The metal parts are more difficult, but doable. It depends what tools you have.
Uncle Bulgaria is offline   Reply With Quote
Reply
