Reply
Old 31st Oct 2025, 3:40 am   #1
tony at home
Default Avo model 8 mk9 odd behaviour on ohms
My meter needle moves to the left when shorting the probes in res x100,its as if the battery is in backwards but its not, any idea?, cheers Tony.
tony at home is offline   Reply With Quote
Old 31st Oct 2025, 7:34 am   #2
Jennings
Default Re: Avo model 8 mk9 odd behaviour on ohms
Did it function fine until recently, or always done that since you’ve had it?
Jennings is offline   Reply With Quote
Old 31st Oct 2025, 10:25 am   #3
avocollector
I have one that does that as well - it's a later mk V model. Not got around to investigating it yet.
avocollector is offline   Reply With Quote
Old 31st Oct 2025, 4:04 pm   #4
Ed_Dinning
MC reverse button?
Ed
Ed_Dinning is offline   Reply With Quote
Old 31st Oct 2025, 7:32 pm   #5
factory
factory's Avatar
The model number or variant has an error, correct me if I'm wrong, but the last version of the Model 8 was the MK7.
factory is online now   Reply With Quote
Old 31st Oct 2025, 8:06 pm   #6
The Philpott
The Philpott's Avatar
Yes.
Model 8, Mark one to seven.
Model 9, Mark two or four.
(I still don't know what the fault is, but Ed may have nailed it)
Dave
The Philpott is offline   Reply With Quote
Old 31st Oct 2025, 9:15 pm   #7
Chrispy57
The MC Rev button is on a pretty strong spring on earlier Model 8s which seems an unlikely scenario. The later mode 8s have a latching switch, but the OP was strangely specific about the x100 range and it would behave identically on the x1 range if that were the case. DC voltage ranges would also be affected and surely noticed during a cursory check before seeking advice?
Chrispy57 is offline   Reply With Quote
Old 1st Nov 2025, 11:27 am   #8
micheal
What happens if you reverse the 15 volt battery in its holder?
Mike.
micheal is offline   Reply With Quote
Old 1st Nov 2025, 5:00 pm   #9
factory
factory's Avatar
Could there be a possibly of the battery being incorrectly labelled? I seem to remember this happened with some capacitors a few years ago, sleeving with polarity marking was the incorrect way round.
Old 1st Nov 2025, 7:48 pm   #10
The Philpott
Well as the 15v battery is probably composed of buttons, i guess its feasible.
Reply
