Reply
Old 29th Oct 2025, 9:18 pm   #21
trobbins
trobbins's Avatar
Default Re: Quad II - PT autopsy begins...
That's a pretty clear distinction.
Perhaps you just have the knack of restoring poor PT's by un-potting them!
trobbins is offline   Reply With Quote
Old 29th Oct 2025, 9:46 pm   #22
dougietamson
dougietamson's Avatar
I'll still check the winds for a short and hope it's just on the outer filament ones for an easy rewind.
dougietamson is offline   Reply With Quote
Old 30th Oct 2025, 12:41 pm   #23
kalee20
If so, then perhaps if you had time, you could measure the mains primary current with increasing voltage. To me, that could be the better characteristic to use for comparison with a 'good' original PT, and also for comparison with the unpotted PT. For an unloaded PT, the primary current waveform would likely be quite distorted, but an rms value could still be a good comparison metric.
The other valid metric would be 'joule heating' as previously mentioned.
It's worth doing, if you have a Quad transformer that's good, or at least comes intermittently good and you catch it on a good day.
For what it's worth this is the type of characteristic you get (this is actually on a 500W toroidal transformer, 240V nominal primary). I measured RMS magnetising current, and true power using a dynamometer-type wattmeter. You can see that the off-load current is a couple of tens of milliamps, though it starts to take off at 270V.
kalee20 is offline   Reply With Quote
Old 30th Oct 2025, 1:01 pm   #24
Richardgr
I suppose a defective transformer could just be a symptom and not the root cause. Are there other signs of distress in the amplifier?
Richardgr is offline   Reply With Quote
Old 30th Oct 2025, 1:38 pm   #25
G6Tanuki
G6Tanuki's Avatar
Either way, I would not be trusting this failed transformer even if the apparent shorted turns are found and fixed.
It's been cooked in service, meaning the condition of the other windings must be suspect.
A full rewind is the only real way to guarantee any sort of future trustworthiness. You wouldn't want to go away for the weekend without remembering to turn off the amplifier and come back to a fire scene.
"It's not true that I had nothing on. I had the radio on!" -Marilyn Monroe .
Old 30th Oct 2025, 2:12 pm   #26
Ted Kendall
Agree with G6 and RW. They're mullered. Full rewinds - you know it makes sense.
Ted Kendall is offline   Reply With Quote
Old 30th Oct 2025, 5:56 pm   #27
dougietamson
It was serviced by Quad in 1988, some components have been replaced.
Photos of inside attached
ID:	320924   Click image for larger version
Old 30th Oct 2025, 6:46 pm   #28
Craig Sawyers
Craig Sawyers's Avatar
The mains transformer was always somewhat underrated.
Apart from the power amp requirement, also intended to supply power to the preamp, FM tuner and AM tuner. HT and heater supply to all of them. With two power amps, one or the other would have to supply power to a total of 13 valves in the ancillary units.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is offline   Reply With Quote
Old 30th Oct 2025, 7:23 pm   #29
dougietamson
Craig
The 2 sickly Quad IIs also came with the 22 preamp and AM tuner.
Old 30th Oct 2025, 10:44 pm   #30
retailer
Not that long ago I rewound a LUX opt that had been potted in pitch - a third person had started the job and given up so even though a good deal of the pitch had been removed, cleaning it up what remained prior to the rewind was not a pleasant job so I can understand a reluctance, however if you do decide to go ahead Xylene from the local hardware store will dissolve the pitch from the laminations, you'll need to get all of the pitch off to stand any chance of getting them all back in. I left the Lux laminations soaking for a few days and 95% of the pitch just washed off leaving very little to scrub off with a coarse cloth.
retailer is offline   Reply With Quote
Old 31st Oct 2025, 9:01 am   #31
GrimJosef
I know someone who recommended petrol for cleaning bitumen off lams. It does work, but with the obvious risks of fire and benzene (and other hydrocarbons) toxicity.
I've used paraffin (kerosene) successfully. I even once tried it in an ultrasonic bath, with the lams suspended along a wire. I did that outdoors though and spent most of the time some distance away. The ultrasonics heat the paraffin.
Cheers,
GJ
http://www.ampregen.com
GrimJosef is offline   Reply With Quote
Old 31st Oct 2025, 10:01 am   #32
kalee20
I've used paraffin, too - especially if the lams are warm it does a good job. You don't need a lot, use half a cupful, let it soften and remove most of the bitumen. Then another half cupful as a second wash, and a third half-cupful to rinse.
With bonfire night coming up, you've got a ready source of flammable fuel for lighting-up!
Old 31st Oct 2025, 11:53 am   #33
dougietamson
I found a tin of cellulose thinner in the shed, I've tested and it disolves the bitumen nicely.
It's warm today for the season so I can do it out doors for ventilation.
I'm also off down the the mens shed, there might be some 'stuff' donated from items found in memebers sheds that probably fall foul of modern rules
Old 31st Oct 2025, 12:23 pm   #34
toprepairman
Personally I wouldn't bother with a rewind.
Steve of Valvepower Stereo 20 fame has replacement transformers for a very reasonable price.
toprepairman is offline   Reply With Quote
Old 31st Oct 2025, 3:36 pm   #35
Richardgr
Did you see this thread?
https://www.vintage-radio.net/forum/showthread.php?t=210698
Old 31st Oct 2025, 4:17 pm   #36
Radio Wrangler
Radio Wrangler's Avatar
Be careful with cellulose thinners. It's an effective solvent but attacks a number of plastics. However, it is very inflammable and like petrol can fill an enclosed space forming an explosive mixture with air.
The value attached to these amplifiers is a function of perceived originality. So you'd want any replacement to be in something indistinguishable from an original can.
Old 31st Oct 2025, 5:21 pm   #37
dougietamson
The laminations are out, gentle warming of the core and the wax impregnation between them allowed for an easy disassembly with a thin plastic guitar pick.
The 5v wind was 1st off the bobbin, 14 turns of 1mm OD wire, looks a bit rough in places.
Then the 6.3v, actually a 3.15-0-3.15v with a CT (thr 'E') turret) 9+9turns of 1.3mm OD wire, looks ok, the last turn wandered off needlessly close to the laminations.
The HT next, one of the leads fell off, looks like a bad solder joint to the strip of thin corroded copper. may have been arcing too.
Will resume the process during daylight.
photos attached.
ID:	320957   Click image for larger version
ID:	320958   Click image for larger version
ID:	320959   Click image for larger version
Old 31st Oct 2025, 5:26 pm   #38
dougietamson
Quite so, I did buy a suitable modern replacement PT at a very reasonable £61 inc p&p from China with the idea of dropping in in the can, soldering to the turret board and potting it with the original bitumen.
The only way to tell it wasn't original would be to un-pot it or measure the specc to find it has better insulation due to the modern wire coating and runs cooler.
Old 31st Oct 2025, 11:10 pm   #39
kalee20
Super photos!
That actually looks not a very good winding design - there's a lot of wasted space, especially with the 5V winding. Two strands (bifilar), 0.7mm diameter, look as though they would nearly fill the winding width (while still leaving some margin at the edges) if close-wound without the huge gaps between the turns - and would occupy less winding height. And the resistance would be the same.
Old 1st Nov 2025, 12:04 am   #40
dougietamson
Originally Posted by kalee20 View Post
Super photos!
Spot on, and bifilar is so much easier to wind.
Reply
