Reply
Old 20th Oct 2025, 6:43 pm   #1
samjmann
samjmann's Avatar
Default Garrard 401 + Permali SME 2000 plinth. Mounting.
Anyone fitted these two together?
I've been fitting this 401 that's in excellent condition to a Permali plinth to of SME 2000 plinth design.
The deck itself sits on the top board which in turn is supported on 4 springs. These have adjusters to trim the height of the suspended deck/board.
The suspension system does seem rather basic. If the deck is pressed the springs rub against the die-cast cups that are attached to the main body of the plinth. The adjusters have all been lubricated, and a small smear of grease applied to the springs to allow movement in the cups.
The springs clang against the cups and the deck doesn't float very well. There are many 401's that are solid mounted I know.
The new plinth is very heavy and rigid. It is well made.
Any thoughts or comments most welcome. SJM.
It's never been right since we've had it...
samjmann is offline   Reply With Quote
Old 21st Oct 2025, 11:42 am   #2
Beobloke
Default Re: Garrard 401 + Permali SME 2000 plinth. Mounting.
Ditch the springs.
301s and 401s work best when in a rigid and heavy plinth, IMHO. Suspensions do them no favours at all.
Beobloke is offline   Reply With Quote
Old 21st Oct 2025, 11:44 am   #3
wd40addict
wd40addict's Avatar
I'd compare rumble level floated Vs solid, I suspect the latter will win, but you never know.
FWIW when I was first playing about with plinths for my 301 I initially used an 18mm MDF top plate, changing this to 25mm definitely dropped the noise level.
I then fitted the finished plinth with sorbothane feet to offer some isolation from the cabinet it stands on. Plinth is solid, springs were not used I suspect this is a hangover from autochanger type thinking and people putting these decks into Heals and Largs radiogram style cabinets.
wd40addict is offline   Reply With Quote
Old 21st Oct 2025, 12:33 pm   #4
stevehertz
stevehertz's Avatar
No springs. The 401 deck is made to be supported on a strong wooden plinth. I have also damped mine using bituminous damping panels.
stevehertz is offline   Reply With Quote
Old 21st Oct 2025, 4:13 pm   #5
Analogue man
I agree a solid plinth is the way to go.
Graham
Analogue man is offline   Reply With Quote
Old 21st Oct 2025, 5:04 pm   #6
samjmann
samjmann's Avatar
Thanks all for the replies.
I had a feeling solid was the way with this. The springs lift the top-board by about 30mm. If they're removed the top will sit on the corner supports and the transit plate hits the bottom cover!
So I'll have to see what can be done in this respect to lift up the top board.
Regards, SJM.
Old 21st Oct 2025, 5:48 pm   #7
Ted Kendall
Originally Posted by Beobloke View Post
Ditch the springs.
I agree. When Dad mounted his 301 as suggested in the manual, using the Garrard springs, it rumbled, was bouncy and prone to acoustic feedback. Mounting solidly to as large a mass as reasonably possible is the way to go with these.
Ted Kendall is offline   Reply With Quote
Old 22nd Oct 2025, 12:19 pm   #8
Craig Sawyers
Craig Sawyers's Avatar
FWIW I use one of these for my 401/SMEIV
https://www.peakhifi.co.uk/cgi-bin/ecom.cgi?Command=ShowProduct&db_pid=774
Cheap it is not. But as compared with the cost of the deck/arm/cartridge, perhaps not ridiculously expensive.
Than I bought the lid and hinges to stop the cat from taking too much interest in a spinning disc...
There is no perceptible rumble at all.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is offline   Reply With Quote
Old 23rd Oct 2025, 4:20 am   #9
analogadikt
Some photos of the plinth shall help. I agree with suggestions to ditch the springs. Could you share from where you sourced the plinth?
Regards,
Anwesh
analogadikt is offline   Reply With Quote
Old 27th Oct 2025, 11:36 am   #10
samjmann
samjmann's Avatar
Here's a few photos of the plinth. You can see the corner blocks I've added to lift the top board. I'll fit a layer if anti- vibration tape to the block tops.
With the deck in place this is all very heavy!
Anwesh: The plinth was a special order. If you're really interested, send me a PM and I can give you more details.
SJM.
ID:	320764   Click image for larger version
Old 13th Nov 2025, 12:56 pm   #11
analogadikt
SJM.
Hi!
I have sent a pm to you a few days ago. Have you seen it?
Regards,
Anwesh
Old 13th Nov 2025, 2:24 pm   #12
Cobaltblue
Cobaltblue's Avatar
Originally Posted by analogadikt View Post
Hi!
Regards,
The OP has not logged in since the 4th November so he will not have seen it yet.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline   Reply With Quote
Old 13th Nov 2025, 8:00 pm   #13
qualityten
Looking at your plinth, I suggest you try it with squash balls in each of the corners, resting in the hole illustrated in your first pic. I have found this sounds best with my 301 and 401. I have tried other arrangements, but prefer the top board being supported in this way. Using various SME 3009 tonearms.
qualityten is offline   Reply With Quote
Old 16th Nov 2025, 5:15 pm   #14
samjmann
samjmann's Avatar
Thanks for the advice qualityten. May well try it and see.
analogadikt: Sorry, have been very busy recently, just seen your message today. I'll get the details and send you a PM.
SJM.
Old 16th Nov 2025, 8:49 pm   #15
samjmann
samjmann's Avatar
Here's a few pictures of the assembled deck.
Just the re-polish of the original lid to do now.
It really is heavy. 8mm thread bolted feet are for the base
SJM.
ID:	321592   Click image for larger version
ID:	321593   Click image for larger version
ID:	321594   Click image for larger version
Reply
