| Vintage Test Gear and Workshop Equipment For discussions about vintage test gear and workshop equipment such as coil winders. |
#1 |
Hello, anyone who may have a copy of Philips GM2890 FM signal generator , in pdf format, service manual or user manual?
Hope for the best : Thorvald |
#2 |
#3 | |
#4 |
Hello kaesz and many thanks for answer. I already have checked up Elektrotanya, but only circuit diagram was available. Regarding the other adress, I have tryed several times but for some reason the payment for loading down a copy was denied. Due you know if the manual is ok for pdf download
??Kind rgs: Thorvald
#5 |
If you are logged in to radiomuseum you should be able to download the 3 pages of the manual. I just tried and had to hit the button marked ID = 138774 to enable the images to be enlarged.
If you can't download them, email me and I can send them over.
- Julian It's good here
#6 |
Hello again Julian, if possible could you kindly e-mail me the pages!
#7 | |
you have to click on the selected site to download it, i.e.; www.radiomuseum.org/dsp_guest_schema_register-ng.cfm?schaltplan_id=51134 Than answer if you are a robot, give your emails data. From your received doc (3x /24hours and max 10 in 30 days if you don't have membership-that cost €20, but only one time), on te second pdf site you can see the wished documentation, not a rocket technik ...
#8 |
Hello, searching for service or user manual for Philips GM2890 FM signal generator.
