#41 |
One thought in the back of my mind.... What if those output transformers have only 15 Ohm secondaries?
That could be awkward with modern speakers. Speaker development over the years has made significant improvements in quality, but usually by sacrificing efficiency. They've been taking a free ride on cheaper power from solid state amplifiers. The dominance of 8 Ohm speakers is to suit solid state amplifiers. Tracing the output circuitry should help, and transformer turns ratios can be measured. David
#42 |
Looking at the pictures of the underside again it would appear that the transformer secondaries have a number of taps so should accommodate all speaker impedances.
I would recommend the OP gets in touch with Grim Joseph of this parish who I believe is not too far from him and and he could easily guide you through the amp. |
#43 |
Good advice re: GJ. He will have a bench HT PSU with current limiting, as well as dummy loads, which will make for the safest way to revive the amp.
#44 |
As trobbins pointed out earlier, the two secondaries are wired differently. It appears that each transformer has two secondary windings, wired in series on one channel and in parallel on the other...
The jumper wires are neatly formed so it doesn't look like it was just for a quick test. I wonder why it should end up that way?? It seems unlikely that it's to correct a manufacturing error in one of the transformers, so one explanation might be that at the end of its previous life it was being used with two different speakers with different impedances ? Although given the attention to detail in construction that might seem out of character? Cheers |
#45 | ||
He's a little out of the way, but his website gives a promising impression. I'll certainly bear him in mind. |
#46 |
I've done some resistance checks between the amplifier output transformer pins, and there seems to be a short between pins 1, 2, 3, 4, H, J, K, and L (numbered as per photo). Am I right in thinking this does not bode well?
Here are the other results I got; all just rapidly increasing or decreasing numbers - no fixed results. Is it worth checking the remaining pins? 1-2, 3, 4: short 1-5: 100k, increasing (200k setting), or 500k & decreasing (2M setting) 1-6: 29k & increasing (200k setting), or 68k & decreasing (2M setting) 1-7: 15k & increasing (200k), or 30k (2M) 1-8: 1.3M & decreasing 1-9: decreased to 75k, then started increasing 1-10: 3M and decreasing 1-A: 2M and decreasing 1-B: 1.5M and dec. 1-C: 1.2M & dec. 1-D: 1.5M & dec. 1-E: 1M & dec. 1-F: 1.2M & dec. 1-G, H, J, K: short 1-6, 1-7, 1-8, 1-9, 1-A, 1-B, 1-C, 1-D, 1-E, 1-F, 1-G: open 1-H, 1-J, 1-K, 1-L: short 2-3, 2-4: short 2-5: dec. to 63k, then inc. 2-6: 2.5M & dec. 2-7: 1.4M & dec. 2-8: 1M & dec. 2-9: 15k & inc. 3-4: short |
#47 |
Are you sure it's a short and not low resistance?
#48 |
My guess is that 5 and A are linked together because they are the HT connection.
The Orange wires may go to the screen grids (G2) and 7 & 8 go to the Anodes. Please measure the resistance from 5 to 6 and then 5 to 7. Then measure 5 to 9 and 5 to 8. Then measure B to C and B to D. Then measure B to F and B to E. |
#49 | |
Yep.
5-7: 290 5-8: 227 5-9: 92 B-C: 86 B-D: 216 B-E: 277 B-F: 121 |
#50 |
I agree that it won't be a short but just a very low resistance, which would be expected on an output transformer secondary. I actually think that unless anyone has done something really stupid with this amplifier in the very recent past then there will be absolutely nothing wrong with ANY of the transformers. It's been very neatly constructed, probably the best I've ever seen and anyone messing about with it would have likely disturbed some of those very neat connections and there's absolutely no sign of that.
The one thing that we don't know is how well it originally worked. I say this because it's obviously homemade, but to a very high standard. There's some odd things about it that perhaps point to problems when first tested in that very strangely the power supply chassis has been spray painted black on the inside - not a good idea! There's a lot of fixtures that have been made without consideration for efficient grounding and you can see evidence of where there's been a problem with the transformer mounting bolts having to be removed and the paint scratched off the mounting points for a couple of them. Valve hats on the output valves is also a bit of an odd one to me. I agree that the missing control unit is almost certainly a passive unit and this is likely to have been mounted into a built in cabinet of some sort, probably a large hi-fi corner unit next to a fire place in a living room somewhere. I'm not sure whether the mains comes from the Bulgin input and goes straight to the transformer. You'd expect there to be some sort of 'user' control panel mains switch somewhere, although these often get bundled with the wiring up to a control panel, this isn't a good idea as regards to hum pickup, so may have not been done this way in this instance. I suspect that this amplifier setup was built and installed in a hi-fi cabinet built into a house living room somewhere, and the person who built it died and house clearance people came in and removed what was easily accessible and left behind what wasn't, ie, the bolted in control unit and all the interconnecting wiring loom with its plugs and sockets that would have still been connected to it. Those two units, the amplifier and its power supply would have been easy to remove from the cabinet, as it's obvious that they weren't fixed and were just free standing - the brass threaded inserts on the bottom of the amplifier chassis would have been for fixing a base cover plate, if one were ever fitted to it...well that's my opinion and there's a lot of guess work going on here, but I suspect that I'm not far off the truth! You definitely need to go back to the auction house ASAP and see if you can find out where it came from. I suspect that the missing parts won't be there, but still in the house that got cleared out, so you need to be quick! Last edited by Techman; 4th Oct 2025 at 2:16 pm. Reason: Minor corrections where spotted. |
#51 | ||
#52 | |
If the reception give you the cold shoulder, don't be afraid to go out the back if you can and have a word with some of the other staff such as the porters etc. They may be able to tell you who brought the units in if you approach them the right way. |
#53 |
Silicon is spot on with the primary side of the transformer connections.
Techman may be incorrect saying the missing control unit is almost certainly a passive. I suspect that the regulated HT voltage would be for an active pre amplifier or possibly a tuner? The unit looks suspiciously like a stereo version of the ultra linear Mullard 5-10 but the transformers do look a bit on the big size for a ten watt amp. From the first pictures the Jones connector on the back appears to have only four pins so simply 6.3V heaters, HT negative and HT positive. The colours of the wires make it obvious which is what. Instead of speakers ten ohm ten watt resistors would make a safe load. I am not suggesting that the unit should be powered up without taking the usual precautions though. Last edited by See_Mos; 4th Oct 2025 at 2:41 pm. |
#54 |
I originally thought that it might have been a 'powered' preamplifier, but then changed my mind, however, you could well be correct.
I always tack in watty wire wound resistors under the chassis onto the speaker connections in place of actual speakers as a 'load' when I'm working on an amplifier like this, as suggested in the above post, it saves a lot of 'noise'! That amplifier will likely just need several of the original paper type coupling capacitors replacing and then it's likely to just work, that is once the interconnections are sorted out. |
#55 |
Although the resistance is not directly related to the number of turns, the screen grid tap on the output transformer primary is about 40-45% of the anode winding size.
For a given number of turns, the windings on the inside of the core need less wire than the windings on the outside of the core and therefore have a lower resistance. |
#56 |
After a bit of cleaning up, the transformers appear to be stamped "P.P.L.7".
#57 | |
#58 | |
That multipin Jones type plug might be available from somewhere. Someone might even have one in their junk box. I've noticed that there's a period Leak control unit that could well be matched to that amplifier in the 'for sale' section of this forum at this very moment if it hasn't already been sold. It's got 'octal' connections that would have to be matched up. Edit: third item in the link below:- https://www.vintage-radio.net/forum/showthread.php?t=222694 Edit again: that control unit is probably mono, so no good for this amplifier. It's also 'collection only'. Last edited by Techman; 4th Oct 2025 at 4:56 pm. Reason: Added link to advert. |
#59 | |
This looks like it would work provided that that one thick round pin could be removed. There's a few on eBay, but they all have that one thick pin. Do you think it's worth buying? |
#60 |
In line with my A.W.A guess, I wonder if it was a monitoring amplifier for some of their pro gear, thus well made and rare, especially in this country.
